Results 1 to 4 of 4
Reload Thread: box guidance
    yz_gt69's Avatar
    yz_gt69 is offline Senior VIP Member
    Dec 2003
    canada
    34
    339
    Icon14 box guidance
    hey guys,
    i have a 66 chev reg cab step side, after moving the tank to the frame i have built a box 5" wide at the top sloped to 6.5" wide at bottom, running 48" wide by 16.5" tall (interior measurements) pending my calculations are right thats 3.4375 ft^3 - the .22 ft^3 my two mtx 12's will take up gives me 3.22ft^3. the WINisd says my ports should be 1 circular at 14cm x 7.4cm.
    can anyone verify this, any suggestions about this setup, it would be much appreciated.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Re: box guidance
    Well here's the numbers I get:
    The big part of the box:
    48 x 5 x 16.5 / 1728 = 2.29
    The small part of the box:
    48 x 1.5 x 16.5 / 2 / 1728 = .34
    The whole box:
    2.29 + .34 = 2.63cu' total
    Subtract your sub displacement and you get 2.41. Depending on tuning you still need to account for port displacement also. In WinISD, a 2.4cu' box tuned to 32Hz would call for a 4" round port to be 11" long...which gives you .08cu' of port displacement. Now you box is 2.33. (I'd just keep the port the same size as it would be in a 2.4cu' box...won't make that big of a difference.) If your looking at a round port, I suggest looking at a Precision Port...can be found at partsexpress.com
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    yz_gt69's Avatar
    Dec 2003
    canada
    34
    339
    my little box knowledge
    hey thx for the help, i'll hopefully get them mounted up and the ports in to see how it works.
    does it matter where the port is located on the box? logically i was thinkin between the two subs on the top of the box but what do i kno?
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    Re: box guidance
    That would be a good place. I always like to put the port in the middle if I have 2 subs.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  1. basic box questions
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 12-22-2003, 05:04 AM
  2. better box building...
    By rocktonic13 in forum Enclosure Design & Construction Help
    Last Post: 12-21-2003, 01:12 PM
  3. just made a box
    By bass maniak in forum General Discussion
    Last Post: 11-30-2003, 05:32 AM
  4. help me with a box for JBL GTI 10s
    By slug420 in forum Enclosure Design & Construction Help
    Last Post: 10-28-2003, 10:51 AM
