Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: 2 15" davinci's in my golf
    idontwant1's Avatar
    idontwant1 is offline Member
    Dec 2003
    the megacity
    55
    Icon10 2 15" davinci's in my golf
    hey guys i need a bit of help ..here goes
    i just baught 2 15" soundstream davinci's stream sya optimal box would be 1.5 cube box with a 4"x12" port ... per sub
    now i was thinking a box with 2 chambers each chamber bmountedeing 17x17x10.5 approx 1.78 without the port or sub mounted ...what do you guys think i can stretch the 10 to what ever number to make this work better .. also what size slot port would be needed ...im leaving it with you guys now
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    Re: 2 15" davinci's in my golf
    anybody .........
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    heeeellllllllppppppp
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    anybody there?
    havoc06's Avatar
    havoc06 is offline The Juggernaut
    Jun 2003
    VA
    36
    461
    you question is a bit confusing...try to rephrase and i will help you
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    thanks havoc heres the rephrase
    i hav 2 soundstream davinci 15"s the onoly info that i have to build a box is each sub needs a 1.5 cube box with a 4"x12" port
    so heres what i want to build a box that has 2 chambers each measureing 17"x17"x10.5" internally approxamatly 1.78 cubic for each sub now will the sub basket and port bring me down lower than 1.5 cubic foot or shouldl i be ok and how would i convert a 4x12" round port to a slot port
    thanks alot for the help
    Jayson Hisel's Avatar
    Jayson Hisel is offline KUSTOM SOUNDS
    Dec 2003
    IMPERIAL,CA
    41
    24
    why dont you make one box 3.56ft3 (1.78 x2) with the port in the middle 2 inchs wide by 17 inchs tall ( the internal length of the box ) x 7.7 tunned @ 35 hertz
    jayson
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    would the port still be 12"deep and i might be amping the subs seperatly in the end so i figured dual chambers might work better but i like the simplicity of a single chamber with 1 port
  9. #9
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    hello ......
  10. #10
    havoc06's Avatar
    Jun 2003
    VA
    36
    461
    ok this is what you do. Find the displacement of the sub. This is how much air space the sub takes up. Add that to 1.5, and you should see how big to build your box. If you dont want to do that, somewhere around 2 cubes before port and sub displacemt should be ok. To find out what a 4 inch port comes to in sq inches, you do Pi*Radius Squared which is about 12.5 sq inches. You can build the square port that is 12.5 sq inches to be the same as a 4 inch opening. Personally i would do a bigger port, something around 30 sq inches to make it sound better.
  11. #11
    havoc06's Avatar
    Jun 2003
    VA
    36
    461
    And if you are using 1 amp, use a single chamber, and just make two ports. a single chamber makes it easier to ensure the subs have the exact same air space
  12. #12
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    so youd go a 2 cube box with a 30 sq inch port
  13. #13
    Dec 2003
    IMPERIAL,CA
    41
    24
    do the same chamber and single slot port its tunned the same as the round port you wanted to use and you can use one amp
    jayson
  14. #14
    idontwant1's Avatar
    Dec 2003
    the megacity
    55
    so ill make a 4 cube single chamber box what size should the port be
  15. #15
    havoc06's Avatar
    Jun 2003
    VA
    36
    461
    ok do this 4 cube box. 1 port 15x3 opening, 26 inches long. That should sound good.
  1. RE XXX 15" vs. IA DP 15"
    By flex in forum Subwoofers
    Last Post: 12-17-2003, 09:45 AM
  2. RE XXX 15" vs Crystal Compx2 15"
    By Digita187 in forum Subwoofers
    Last Post: 12-15-2003, 05:59 PM
  3. Replies: 1
    Last Post: 11-25-2003, 12:08 PM
  4. Can I put a Diamond S600s in the Golf IV door???
    By Guijs in forum Enclosure Design & Construction Help
    Last Post: 11-23-2003, 09:07 PM
  5. 15" RE SE or 15" RE HC or 15" DD3515
    By BigJohnson in forum Subwoofers
    Last Post: 07-14-2003, 10:49 PM
