Results 1 to 1 of 1
Reload Thread: Enclsoure size for a Diamond TDX 12"
    Sturge's Avatar
    Sturge is offline Member
    Dec 2003
    Oregon
    36
    Enclosure size for a Diamond TDX 12"
    Okay..I started my query over in the install forum, but I think now it belongs here.
    Here's my setup:
    I currently have the following setup in my 97 Tahoe:
    Alpine CDA-7998
    Diamond Hex S600s in the front
    M361 in the rear
    Diamond D5 600.2 for the front and rear
    Diamond TDX 12D4 (dual 4 ohm)
    Diamond D5 1200.1 for the sub
    Basically I'm getting a disappointing level of bass from my 12" TDX. I thought it was a wiring problem, but it's all wired fine (parallel for 2 ohms). The sub is firing to the rear of the Tahoe, with about 16" between the sub and the rear doors.
    I did some measuring and it appears that my enclosure has 1.915 cubic ft of airspace (2.055 without sub displacement). Is this too much for a TDX 12"? The specs show from .55-2.5 cubic feet, but would I be better off with closer to 1.5?
    I'm really trying to avoid dropping another grand on a second sub and a new box.
  1. Amp for 2 12" Diamond Audio TDX's
    By BAsK510 in forum Amplifiers
    Last Post: 12-18-2003, 02:53 PM
  2. Diamond Audio TDX 12"...
    By slick316 in forum Subwoofer and Speaker Reviews
    Last Post: 10-23-2003, 12:08 AM
  3. box size for re se 12"?
    By Doberdad in forum Subwoofers
    Last Post: 08-25-2003, 02:25 AM
  4. Looking for amp for Diamond Audio M3 12" 4ohm
    By Sun in forum General Discussion
    Last Post: 08-09-2003, 10:24 AM
