Results 1 to 5 of 5
Reload Thread: fibreglass temperature
    surly's Avatar
    surly is offline Junior Member
    Dec 2003
    Winnipeg, MB, Canada
    37
    what is the best temperature to work with fibreglass? i'm planning on doing this during winter in a garage with a heater on... so it will be above freezing, but not by much... would this be ok?
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    37
    8,477
    32
    Re: fibreglass temperature
    Whatever resin you decide to use should have a recommended temperature on it.....if it's colder outside than that temp., use a little more hardener; if it's hotter than that temp, use a little less. Also, remember if it's colder to give the mold more time to cure.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    Dec 2003
    Clayton, NC
    32
    93
    a friend of mine made the mistake of fiberglassing a box in late november it was like 40 degrees and he now has to completely redo the box becasue it didnt harden properly. so check those temps well!!!
    2 Audiobahn AW1206T
    Audiobahn ABC600Q Components
    Panasonic CQ-DF903U Deck
    PROFILE CA1200 Amp
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    36
    368
    Just make a hot batch (but not too hot, dont wanna see anyhitng melting)
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Mix it a little hotter than normal. ANd give it plenty of time to cure. You can use your heater to help you cure the glass as well.
    5 % equipment
    90 % install
    5% beer
  1. Nedd Fibreglass Instructions!
    By MXJMR in forum Enclosure Design & Construction Help
    Last Post: 07-22-2003, 07:33 PM
