Results 1 to 9 of 9
Reload Thread: Am I gonna blow this?
    86TaurusHSC's Avatar
    86TaurusHSC is offline Junior Member
    Dec 2003
    NY
    Im putting together a system with an Audiobahn A1801T (1000peak, 560rms @2ohms) with one Kicker CVR15 (1000 peak, 500rms @ 2 ohms). I built a box yesterday measuring 26x20x16 yielding ~4.8 cf. The min for this speaker is 1.8 and the max is 5.0cf. I do have alot of bracing on the inside, so it will probably be about 4.5 or so cf. Is this gonna melt if i put it to its max? Should i put some extra panels on the inside to take up some cf? btw its a sealed box.
    tobz's Avatar
    tobz is offline Independant Thinker
    Nov 2003
    MN
    31
    507
    Re: Am I gonna blow this?
    That should pound very nicely with no problems. You might want to add bracing simply because the box might flex being that large and sealed, but you shouldn't blow the sub. Have fun bumping, and let us know how it turns out!
    Dec 2003
    NY
    Thanks for the info. I am working on the bracing now, Im using red oak 2x3" strips (i think). Im not sure if this is the best wood to use, but its the only one out of about 7 different woods that either didnt break when i flexed it, or didnt sound like it was going to break. Im doing all the corners with the wood, and i am planning on doing a cross brace on all but one panel(the one that holds the woofer). There doesnt need to be any other material inside the box does there? would some sort of rubberized coating on the inside help at all?
    tobz's Avatar
    Nov 2003
    MN
    31
    507
    Nah, I would just put a plus-sign style brace in the center to all sides (except the front of course, since there is a hole there), and you should be golden. If you want, you can probably do do two plus-sign style bracings towards the sides, that way you can brace all the way to the front wall, and then run one piece from left to right through both +'s. Go ahead and brace it up and see how she wangs!
    T.J.
    Dec 2003
    NY
    I was reading through the kicker tech manual and it says that "all sealed boxes should be 50% filled with loose polyfil". What does it do?, do i need it? thats probably a dumb question since the manual says you do...... but if the box is 50% filled, isnt it going to get into the subwoofer? or does the box have to be on end or something to keep it all seperated? im confused
    Dec 2003
    NY
    *BUMP* (sorry)
    lombardo's Avatar
    lombardo is offline bass massage
    May 2003
    Rochester, MN
    26
    510
    No it won't get in the woofer. Hit up walmart and for 3 bucks you can get a 48oz polyfill bag just loosen it up and fill it about half the box. In theory it slows down the sound waves tricking the speaker into thinking it's in a larger box. I put it in with my brahma and I liked it.
    2000 black Audi A6 2.8
    stock components
    RE HC15"
    tsunami 1100d (kills kids)
    building a 4^3cuft tuned to mid 30's
    some nasty sauce mixed in there.
    AIM - fincorny82 2000
    E-mail - l0mbardo@hotmail.com
    Dec 2003
    NY
    I just wanted to thank everyone for their help in me choosing my system. Unfortunately on wednesday i had some heart problems and totaled my car going 40, into a power pole. So now i have a system, but i have no car. Oh well thats how it goes, at least i can have a really bassy system on my computer or something. Well, Thank you again to everyone for their help.
  9. #9
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,491
    thats too bad dude. hope u get some wheels.
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
  1. so many amps, so little money
    By eviltuna7 in forum Speakers
    Last Post: 12-10-2003, 11:13 PM
  2. Did i blow my sub?
    By NitroDuck in forum Subwoofers
    Last Post: 11-19-2003, 05:50 PM
  3. blow subs
    By morganator88 in forum Subwoofers
    Last Post: 11-15-2003, 03:54 AM
  4. needing a pro installer
    By boomsta in forum General Discussion
    Last Post: 10-30-2003, 04:58 PM
  5. Would this blow up my sub or amp?
    By swtguy in forum Wiring, Electrical and Installation Help
    Last Post: 10-16-2003, 10:16 PM
