Results 1 to 4 of 4
Reload Thread: Got done building a box. Will insulator count as displacement?
    jlaudiow6's Avatar
    jlaudiow6 is offline Member
    Apr 2003
    san diego
    34
    121
    I just built a fiberglass box for 2 12 w7. It fits nicely in the car but in order for it to look how i wanted i had to make the box bigger than the recomended specs..
    Its a sealed enclosure. Kind of makes a hollow noise some times. Like the box is too big. I have like 2 yards of fleece left over which i think will make a good insulator inside the box.
    I was wondering if that the fleece counts as a displacement to make the volume in side the box smaller.
    thanks
    jlaudiow6's Avatar
    Apr 2003
    san diego
    34
    121
    Re: Got done building a box. Will insulator count as displacement?
    i just placed the fleece in there and the hollow sound is gone but is the fleece strong enough to consider it as a displacement? or do i need to put some blocks of wood in there?
    beast644's Avatar
    beast644 is offline Junior Member
    Sep 2003
    Chicago
    18
    the fleece got rid of the hollow sound becauses it acts as dampening, which is necessary in any sealed enclosure. But its not changing the volume of the box, if it sounds good, i wouldnt worry about changing the internal volume, but u can try droping somthin solid in there to see how it sounds (but secure it so i doenst rattle around and dammage ur sub). U might want to try replacing the fiberglass fleece with a material designed for dampening, such as Acoustastuff.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Quote Originally Posted by beast644
    Or poly fil. It cheap and at Wal-Mart. Use about 1lb./cu'.
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  1. fiberglass box im building for a z28...
    By saber in forum General Discussion
    Last Post: 03-10-2004, 08:21 PM
  2. im a newb to box building... help me out
    By rocktonic13 in forum Enclosure Design & Construction Help
    Last Post: 02-29-2004, 11:54 AM
  3. building a box
    By Mr. Marcus in forum Enclosure Design & Construction Help
    Last Post: 12-04-2003, 01:56 AM
  4. building a ported box (2cu ft) for 10 inch
    By jlaudiow6 in forum Enclosure Design & Construction Help
    Last Post: 10-08-2003, 01:52 PM
  5. Building box for a 1800WRMS system
    By ferret7cs in forum Enclosure Design & Construction Help
    Last Post: 09-23-2003, 01:13 PM
