Results 1 to 11 of 11
Reload Thread: ideas on how to make the terminals of my box.
    cj407's Avatar
    cj407 is offline Banned
    Jun 2008
    Orlando, FL
    2,780
    i was thinkin of a bolt thru the wall of the box and 2 nuts on the outside. so that the nut closest to the mdf would hold the bolt tight and then the other nut would tighten up to the other one to keep the leads from the amp tight to the bolt (which the leads inside the box are hooked to)
    any other ideas?
    can make a picture if needed.
    t1990le's Avatar
    t1990le is offline CarAudio.com Elite
    Dec 2008
    Kennesaw, Ga
    1,106
    1 Post(s)
    Re: ideas on how to make the terminals of my box.
    that seem like it would give you the best connection. You could direct wires from your subs to your amp via a hole in the box and seal it up with silicone or something simillar.
    2004 Ford F-150:
    HU: Panasonic CQ-C8803U
    (4) Polk MM 6x8s, (4) Kicker CVR 10s
    RD 1750.1 & MTX BTP 504
    2 runs 1/0 Welding Cable, 8awg & 14awg speaker wire, Optima YT, Custom BP 215 amp Alt, Big 3 in 1/0
    cj407's Avatar
    Jun 2008
    Orlando, FL
    2,780
    hdc3 18...10(or small 8) gauge direct connect leads....so hard to put 2 8 gauge wires into an 8ga opening unless i use a 4 to 8 gauge reducer...but i was think the other way would be simpler for daily to comp switch.
    t1990le's Avatar
    Dec 2008
    Kennesaw, Ga
    1,106
    1 Post(s)
    how are you trying to wire the sub up?
    2004 Ford F-150:
    cj407's Avatar
    Jun 2008
    Orlando, FL
    2,780
    1 ohm for comps and 4 ohm for daily.
    dman4486's Avatar
    dman4486 is offline RememberedHowToChangethis
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    Quote Originally Posted by cj407 View Post
    so if the subs are dvc, put 2 pair of bolts per sub and when you want to change the wiring you don't have to remove the subs from enclosure.
    Autos:
    '12 Audi A3 S-Line TSI 6MT
    '96 Honda Passport 3.2L v6 4X4 5sp
    2015 Victory Cross Country Tour 106
    2015 Ford Escape Ecoboost
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
    Apr 2009
    dallas tx
    6,930
    55 Post(s)
    do it like this and just wire the tops (positive) together then to the amp, and then the bottoms (negative) then to the amp for PARALLEL, 1 ohm
    series is hard to explain without pics so ill just leave the parallel info for now
    Apr 2009
    dallas tx
    6,930
    55 Post(s)
    like this for series
  9. #9
    dman4486's Avatar
    Jan 2008
    Fountain Inn, SC
    9,332
    6 Post(s)
    ^^^^exacry what I was sayin
    Autos:
  10. #10
    oldschoolboomer's Avatar
    oldschoolboomer is offline CarAudio.com Veteran
    Jul 2007
    white house, TN
    2,149
    1 Post(s)
    141 Post(s)
    any other ideas?
    I do that myself most of the time. works great and is cheap and solid.
    refs: hundreds
  11. #11
    satwilson's Avatar
    satwilson is offline Junior Member
    Oct 2009
    LAWRENCE
    Icon10 Re: ideas on how to make the terminals of my box.
    I use the bolt thru with these details: Use brass or stainless bolts to prevent corrosion, large washers on both sides and epoxy on the bolts where they pass thru the box to further prevent them from turning as you tighten the nuts. More importantly rather than just drilling thru the box, decide where you want the terminals and cut out a 3"x3" opening and then on the INSIDE of the box glue and screw(or staple) a 4"x4" piece that covers the opening, effectively countersinking the bolt attachment area. This makes for a neater look and prevents physical damage or shorting across the terminals. satwilson
