Results 1 to 7 of 7
Reload Thread: Port length inside/outside box
    moorezy's Avatar
    moorezy is offline Senior VIP Member
    Aug 2007
    St. Catharines, ON, Canada
    332
    I need 11 inches of port length in my enclosure.. Can I have 6 inches inside and another 5 on the outside? does that change anything or is 11 inches 11 inches? I'm using a flared port tube.
    Infinity Kappa Perfect 10 VQ (2)
    Infinity Kappa Perfect 6.1
    Infinity Kappa ONE
    Infinity Kappa FOUR
    Knu Flex 1/0
    Knu Klarity RCAs
    Pioneer AVH-4000DVD
    dB Electrical 200 amp alt
    2000 Lincoln LS V8
    phemps's Avatar
    phemps is offline CarAudio.com Elite
    May 2009
    PA
    1,262
    Re: Port length inside/outside box
    yep it can be done. try to round your port edges off to reduce port noise though
    Refs: Rio, DbzArson, goodstuff, Worstenemy453
    Quote Originally Posted by Altec View Post
    Then obviously I am asking the wrong person, because you don't know how to hook up subs if they sounded like "****". Maybe learn your ohms and your diagrams before you call something ****. Learn to make boxes to specs and use the right wires and its called dynomat. Then maybe your car wouldn't of sounded like ****, yeah?
    SomeGuyDude's Avatar
    SomeGuyDude is offline CarAudio.com Elite
    Aug 2009
    Canton, OH
    592
    Port location makes no difference as long as it's attached. You can do all in, all out, half and half, whatever.
    And now... now, what joy will I have left to live for?
    moorezy's Avatar
    Aug 2007
    332
    That makes designing box much easier, thanks! Build is going to start in a couple days
    Infinity Kappa ONE
    Infinity Kappa FOUR
    Knu Flex 1/0
    Knu Klarity RCAs
    Pioneer AVH-4000DVD
    2000 Lincoln LS V8
    Decaf's Avatar
    Decaf is offline Coffie w/o the Hype
    Aug 2009
    Northern Illinois
    168
    19 Post(s)
    wtf kinda answers are those, lol
    if u have it 5 in and 6 out vs all in it will change ur volume and tuning... u will have more volume inside the box... and lower tuning, so figure out the displacement of the port that is now outside of the box... add that into the total volume of the box, and u will have ur final tuning
    basshedz06's Avatar
    basshedz06 is offline CarAudio.com Elite
    Dec 2007
    Tupelo, MS
    537
    i use to wonder that, but the above poster got me thi nking the samething. that would increase volume an thus lowering tuning some more. but not by much cause aero' ports don't take up that much area in a box. i would say go for it cause i have seen many guys do that an be fine.
    TEAM DB DRIVEN
    keepin it real wit some gangsta ****
    thegreatestpenn's Avatar
    thegreatestpenn is offline lazy genius
    Nov 2007
    columbus
    9,288
    27 Post(s)
    it can be done, but securing the port will take some finesse and as exact a hole cut as possible. Also make sure you don't screw up displacement of the port that is inside the box or the tuning will be way off
    http://www.caraudio.com/forums/buyer-seller-feedback/401249-thegreatestpenn-feedback-thread.html
    2k2 honda civic
    summer build
    audison sr4 on focal polyglass 165vb components active
    soundstream rubi1.2500d on dc lvl4 xl 18
    pioneer deh-80prs
