Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Stumped on Astro NW box
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Trying to get an Astro louder. Looking for max SPL, nothing else matters. Will be using 2 BTL 15s. Everything has to be in the very back behind the second row of seats and under 25" tall.
    Original box he has was 10 cubes, tiny slot port all the wal across the bottom. Port was really long, and he said it was tuned to like 27-29hz. Subs facing up, port back. That box did a high 147 @ 53hz.
    I did a new box for him, 8 cubes @ 39hz with 102in^ of port. Subs up, port firing back on the drivers side. This whole box was 1.5" thick. This box only did a high 146 @ 53hz.
    From what Ive seen the BTLs always liked smaller boxes, so I shrunk it down to 4 cubes a sub (still big for a 15) and raised the tuning over 10hz higher and gave a whole lot more port, but still lost a whole DB...
    The dimensions that we have are 49" wide, 22" tall, and around 40" deep. Anyone have any suggestions? Keep in mind the subs arent seeing **** for power... He said Carlos Rodriguez clamped the SS XXX6500 and he was only seeing 760rms out of it. So Im pretty stumped here. Any suggestions?
    audioarsonal's Avatar
    audioarsonal is offline JaMarcus
    May 2007
    close to home...
    4,165
    1 Post(s)
    Re: Stumped on Astro NW box
    If you aren't running 16v with that amp your wasting your time.Try getting more power first and see what it can do.It could be due to the postion of the box.I know most guys have them mid way forward at the b pillar and say anything behind the box causes a drop in score.
    Just make it as big as possible then start shrinking it from there.You know the drill....
    Bought from:whiteram,Pyro_by_nature,AudioXtremes,Slab,IA2
    Sold to:annarbor84,ssackett,tapout383
    built for:skeptikal,Raid3r89
    SHADY SELLER:memphisman00
    Subs:4 Incriminator Audio Death Row 15's
    amps: Memphis 4K
    [email protected]
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Well its not my vehicle or equipment, and he needs the rear seats in, so it must be in the very back. Think maybe trying something like 5cubes with a big 12" port around 40hz to start with, and trimming from there would be a good way to go?
    18inchjeepin's Avatar
    18inchjeepin is offline CarAudio.com Elite
    Sep 2007
    Muncie, IN
    1,329
    2 Post(s)
    what does he have 1 batt?
    Is there enough room for the port to breathe? Maybe try port up, also was 10 cubes the max box size, usually bigger boxes gain efficiency for low power
    Silver HHR - 155.1 db
    TEAM SOUNDSTREAM
    XS Power
    REFS:jeeper07,thegreatestpenn,TeamPSI(x3),dbman150,bad @SS chevy,tommyk90,*GQ*,THXdts, XxSuperAdamxX,fatboyracing,gymfreak101,LTnChynadol l,amartin_72,avs20,Twisted_0912
    SOLD TO: Kold_Killa,GMCJimmyslt2000,skitzafit,ravens9322,wE rd,jeramydean,Shinju,the12voltsux,gammey4,camaroau dio69,bigwheel15
    TRADED: RnK1026,wasted ink
    ContourSPL's Avatar
    ContourSPL is offline Senior VIP Member
    Jun 2006
    Paoli, IN
    327
    Didn't astros used to be really good in street classes? Back on topic, he won't be very competitive unless he does a NW setup at the B-pillar, if that matters much.
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Not looking to break 160s, just get louder.
    skmfkr's Avatar
    skmfkr is offline CarAudio.com Veteran
    Jan 2005
    Savannah, GA
    31
    6,309
    i think the first box was probly tuned higher. if he peaks at 53hz might as well tune to 45hz or somthin if hes still gonna peak high. and yeah 8cubes is still fairly big for 2 15s my box is only 7.3 for my 2 15s. but if he isnt getting much power out of that amp then the large one would probly help.
    '08 Ford Escape XLT
    2 12" DC XL's + 2 RD D9s
    Selenium and Crescendo on AQ4X90
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Well the original box was built by Will Alfonso, so I guess that its not too bad that a box I designed was only a DB lower than his...
    Maybe a bandpass might work...
  9. #9
    dappa5's Avatar
    dappa5 is offline DO WORK! (if u can)
    Mar 2009
    S.W.FL
    1,850
    39 Post(s)
    Quote Originally Posted by ContourSPL View Post
    thats not tru the box i built or 4 15's subs up /port up took 2nd place SBN
    and that was in street 2 or 3 imo rear seat in /is the point amp rack along front of box angled behind seat got 150 out of 4 mojos on 1k each so press on g-monk you'll get it higher p.s. if you are firing the port back, take trim panels off the doors and add 3/4 mdf then reapply trim / i also did entire roof with two layers of 3/4
    then again this kid just re did his box himself added two more subs and 2 k more power and lost dee beezz so just keep trying lol
    feedback thread
    http://www.caraudio.com/forum/showth...appa5+feedback
    lol the moderators here are GODS word to the wise
    "don't cross them lol
  10. #10
    May 2007
    close to home...
    4,165
    1 Post(s)
    Quote Originally Posted by dappa5 View Post
    If you did all that and only broke 150 then something was wrong.
    amps: Memphis 4K
    [email protected]
  11. #11
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Yeah the white Astro with 6 Mojos? Thats who he is trying to beat. He already has the MDF in the back doors.
  12. #12
    dappa5's Avatar
    Mar 2009
    S.W.FL
    1,850
    39 Post(s)
    lol that's my boy Zack
    he went away from my advice come see me i'll beat him lol
    feedback thread
  13. #13
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    I just dont really know... I thought the smaller box and higher tuning and bigger port was going to be much louder. Hmmm...
    And Ill ask again, who is girl in your avatar?
  14. #14
    skmfkr's Avatar
    Jan 2005
    Savannah, GA
    31
    6,309
    u still got a sundown 3k? try one of those in there
    '08 Ford Escape XLT
  15. #15
    Sep 2006
    Tampa, FL
    7,681
    139 Post(s)
    Might be getting one back. Sold one to a local kid (worked 100% when I took it out) and now like a month later he said he tried to hook it up and it doesnt work. I guess Ill be buying it back now at the same price I sold it when it worked.
    Fuck me.
