Results 1 to 7 of 7
Reload Thread: Check Numbers please?
    Winter_C's Avatar
    Winter_C is offline Teh Pinto Driver
    Aug 2009
    Mitchell, SD
    534
    2 Post(s)
    Ok, making box for two 12" Rockford Fosgate P3's. Came up with the following:
    Length: 39.5
    Height: 15
    Depth: 18
    Comes out to 4.9 Cubic Feet? But that is without subtracting volume for ports and subs i think. Someone help me? tell me total cubes? Did i build it correct?
    With two 4" PVC pipe and I'm thinking 10" deep? have not put in pipes yet so i am asking you. What should i tune it to? and how do i tune? I am new at this, first box ever..
    plugitin's Avatar
    plugitin is offline She Bangs
    Jul 2009
    Da U.P. eh?
    28
    6,473
    111 Post(s)
    Re: Check Numbers please?
    32-35hz ish is what i would tune it to...
    Team DC Audio
    Refs: absoluteaudio, rab, walnut, seedubs1, dbeez, -leister-, Louisiana_crx, bubbagumper6, DS Autpsports, Mr.Ronin_2U, lil98cabrio, wone, micah_jones, grinder1989
    Winter_C's Avatar
    Aug 2009
    Mitchell, SD
    534
    2 Post(s)
    How do you tune?...Call me a moron but never have did it...
    superbang's Avatar
    superbang is offline Senior VIP Member
    Mar 2008
    Long Beach, CA
    456
    5 Post(s)
    port diameter and length + cu^ft = tune
    accroding to your specs you have: (Assuming your using 3/4 mdf) Total 4.89cu^ft
    If you did 2 ports at 4" round by 10" length you should be at about 33hz. VB is then 4.5cu^ft
    bass box is showing to much vent air velocity with just two 4" ports. I'd suggest one 8" port 24" long. Makes your box 34hz
    >>Video of system above^^http://s64.photobucket.com/albums/h1...rucksystem.flv
    SET UP:
    99' M3 convertible
    - Kenwood Excelon KDC- MP828
    - Phoenix Gold 6c comps (kicks) Crystal comp 3.5" coax (door) PPi 5.25" carbon coax (rear)
    - Hifonics Jupiter 4ch amp
    - Phoenix Gold Titanium EQ
    - PA BAMF 5500D
    - Orion 10.2 [1.4cu^ft @ 42hz]
    * 134.6db @ 42hz *
    REF: PsychoTheRapist, Eglish, RAB, bajalion, phensway, scoob8000, SPL-Master, 5.3bowtie, Marcotheclepto, More on ROE [ebay: synddb @ 100%]
    Winter_C's Avatar
    Aug 2009
    Mitchell, SD
    534
    2 Post(s)
    wait wait, 8" at 24" long?...you mean rectangle port? and uh, too much air? so like...tell me what i need to do, if i build it way i am atm will it be ok?
    Winter_C's Avatar
    Aug 2009
    Mitchell, SD
    534
    2 Post(s)
    Finishing box today guys...can anyone tell me if i build it way i said if it will sound good?....shoulod i change length of ports? if so what to? What will that tune it to? I AM SO CONFUSED! HELP ME
    Winter_C's Avatar
    Aug 2009
    Mitchell, SD
    534
    2 Post(s)
    Help Me Please
