Results 1 to 6 of 6
Reload Thread: woodfiller/body filler
    xxxbasshead's Avatar
    xxxbasshead is offline CarAudio.com Veteran
    Jul 2009
    lake forst , ca
    2,360
    43 Post(s)
    to fill in small gaps in on the front of a box is wood filler a good substitute for body filler?(first custom box)
    Sep 2008
    North Carolina
    29
    4,214
    1 Post(s)
    163 Post(s)
    Re: woodfiller/body filler
    I used elmers wood filler and it worked good for me, just takes a while to dry. Works good for filling screw holes.
    Jul 2009
    lake forst , ca
    2,360
    43 Post(s)
    cool yea im a newb to wood working so need to fill in tiny cracks between the boards thx
    tylork92's Avatar
    tylork92 is offline CarAudio.com Veteran
    Nov 2008
    North Carolina
    2,334
    28 Post(s)
    you can either use the wood filler as mentioned above or spot putty.....you can get both in small tubes.
    [/SIGPIC][/SIGPIC]
    93 Ford Ranger
    full fiberglass panels and a-pillars
    XS d6500/ Mechman 260A
    2 SA15s
    Sundown 1500dv1
    Toolmaker plexi, dual inputs, distro blocks.
    bumpin buick's Avatar
    bumpin buick is offline Science is everything
    Jul 2007
    Appleton, Wisconsin
    11,023
    1 Post(s)
    Three steps to filling boxes.
    Start with mar-glass
    then sand and use bondo for smaller holes
    then sand and use icing for the pin holes left over
    thats if you want a perfect finish.
    http://www.caraudio.com/forums/buyer-seller-feedback/305521-official-bumpin-buick-feedback-thread.html
    fbi90909's Avatar
    fbi90909 is offline Panty Thief
    Jun 2006
    Key West, FL
    35
    7,768
    4 Post(s)
    elmers wood filler works just fine. patch, dry, sand with sanding block, beer.
    i will not put **** or outside links in my signature again. if i do i will be banned. all hail the moderators.
