Results 1 to 5 of 5
Reload Thread: Ported Calcuation & other things to max out system- Eclipse Ti: (Project SQ w/ ballz)
    danfortner's Avatar
    danfortner is offline Senior VIP Member
    Mar 2003
    Mystic, CT
    35
    216
    15
    Hey All,
    I bought a 12" Eclipse Titanium back in April. I really like it and have done a few things to improve upon it. I want to keep as good of SQ as I have now and just add some more loudness. Obviously adding another sub seems perfect, but 2 of these things would be total 1500w RMS on my stock alt (about 500 too much), so I would like to see what else I can do to this one only first. But I am wondering now what would you suggest/think of my ideas to maximize the performance of this sub:
    1. The first thing I am definately going to do is port this subwoofer. It has a good Fs to let it perform well in sealed or ported. I just need some help with the calculations. I used eatel.com and came up with 1.2 cuft (I am assuming before displacement, which is .19 cuft) and I used another calculator to come up with 1.5 cu ft. But I read this article Sealed, Ported, eh on SoundIllisions and am basing some of my background knowledge on what they are saying. One thing they say is:
    For an adequate/correct tuning frequency, the equal/greater Vas should yield a flat response where the smaller Vas alignment should look similar to a sealed enclosure but with a steeper roll-off. If you don't meet or exceed the Vas of your ported driver, problems will inevitably occur."
    a. I came up with 1.2 and 1.5 and thats way lower than the vas of this sub, 3.2. So this has just got me wondering if someone else could calculate a ported enclosure for this sub, geared towards SQ. The thiele small parameters are listed at the bottom of this post.
    b. What is a good tuning frequency for keeping the same SQ I had when it was sealed, but adding some SPL? 30hz or should I calculate the resonant frequency of my car to find this?
    2. New amplifier? The RMS of this sub is 750w. I am using a US Acoustics 1000D - 750w @ 2 ohm. People say all the time that Eclipse makes hearty woofers, and that they can take alot. But does that really mean that you should go well over the RMS to increase perfomance. I do not want to blow this sub as it was perty expensive! Would a PPI PCX-1500 be too much (1000w @ 2 ohm) or should I just stick to the 750w if I am worried about blowing it?
    3. Another layer of second skin. I loved the results when I added 45 ft to my trunk, so doubling it might help to keep a little more bass inside.
    Alright thats it for now. Hope you guys can shoot me some feedback.
    THANKS A LOT!
    Eclipse Titanium 12" Parameters:
    DC-R - dual 3.1 ohm
    FS - 27hz
    qts - .30
    vas - 3.2 ft^2
    spl - 89db
    qes - .32
    qms - 5.0
    sd - 490 cm^2
    xmax - 38mm
    woofer displacement - .19 ft^2
    DECK - stock Acura-Bose Premium Sound w/ 6 CD-Changer
    SPEAKERS - 4 stock Bose & 2 stock 6x9's
    SUB - 12" Eclipse Titanium 9122
    AMP - US Acoustics USX-1000D
    EQ's - AudioControl Epicenter
    BOX - homemaid 1.7 cu. ft ported box @ 35hz (w/ neon & plexi)
    WIRE - 4 gauge w/ distribution and power blocks - KnuKonceptz
    DAMPENING - 50ft of Second Skin Damplifier
    CAR - 99 Acura 3.5 RL - V6 w/ 210hp - all stock
    NEXT - replace anything Bose, add HU, add navi
    Warbleed's Avatar
    Warbleed is offline @$$hole
    Sep 2003
    Des Moines, IA
    36
    925
    Re: Ported Calcuation & other things to max out system- Eclipse Ti: (Project SQ w/ ballz)
    Those parameters are pretty far off...
    I'd go with about 1.75-2cf tuned around 30hz for SQ, 35hz if you want more SPL.
    danfortner's Avatar
    Mar 2003
    Mystic, CT
    35
    216
    15
    Thanks, what calculator did you use?
    Hypothetically if 2 cuft @ 30hz was 50/50 SQ/SPL, what would 2 cuft @ 35hz be? Or should I calculate my car's resonant frequency to find the perfect setting?
    Please keep calcuations/opinions coming! - THANX
    danfortner's Avatar
    Mar 2003
    Mystic, CT
    35
    216
    15
    You don't have to calculate these things yourself. I totally don't mind if you can just tell me where to find one, or general ideas how I would determine a perfect box size and tuning frequency for my SQL application.
    danfortner's Avatar
    Mar 2003
    Mystic, CT
    35
    216
    15
    Aight, I trust Jmac, because you're like a legend on this board!
    I am assuming since your an expert you incorporated the .19cuft of displacement of this beast! But I got 1.2 before also, I was just weary that adding .20 cuft to the box and making a port would do something (I have 1 cuft now).
    Anyway, I will post my proposed dimensions, and box design once I figure that out.
    Please, if you come across another calculator or punch the numbers yourself, please post what you get, because it re-assures me, even post if you get something different.
    THANKS
