Results 1 to 10 of 10
Reload Thread: Building box, no idea where to start with plans.
    reclessantics's Avatar
    reclessantics is offline CarAudio.com Elite
    Oct 2008
    SC
    514
    1 Post(s)
    i have used the provided box shindig on excel, and re audio box calculator. i have no idea.
    10 net cubes. 2 MA MJ 18m's. subs forward, port up. 12-16^2 port area per ft^3. tuned to 30hz.
    where should i start?
    (i need to just go straight back to the beginning of planning)
    are all my specs semi right at least?
    altoncustomtech's Avatar
    altoncustomtech is offline SQ or BUST
    Nov 2005
    Monroe City, IN
    38
    377
    1 Post(s)
    Re: Building box, no idea where to start with plans.
    The EXCEL based box calculator that was posted up will give you pretty much everything you need, cut sizes and all.....
    The best way to start is take the numbers, cut it out, build it and try it..... That's exactly how most of us got started.... enter the 10 cubes for the net size, i'm guessing .48 will be close for the sub displacement, enter the tuning frequency and enter the first two dimensions you need for your box.......... then run to the custom slot port tab and follow the cut outs..... glue, screw and build the box by the best practices and give it a try.... it's the only way I know of to find out for yourself unless you have someone else design and build the box for you.....
    -={1998 Chevy Venture Van}=-
    Kenwood KDC-X991
    Hifonics AS62Ci 6.5" Components front/rear
    Sundown SAE-100.4
    Pair of 12" Fi Car Audio Q subwoofers in 4.2cuft NET tuned to 32hz.
    Sundown SAZ-2000D
    REFS -- Bought From: TV559
    Oct 2008
    SC
    514
    1 Post(s)
    word lol sounds good.
    i was just double checking the measurements with the RE box calculator.
    and 12volt.com calcs.
    they don't match, but im sure thats normal lol
    so im going to go with yours. its the **** lol ive been playin with it for a few days now. ill just wing it and see what happenes
    Nov 2005
    Monroe City, IN
    38
    377
    1 Post(s)
    I've never seen ANY box calculations match from anything.... seen them close but never match..... none of theirs will match mine anyway because mine is taking in account the displacements of the woofer(s) and the port, I don't believe any of them do that, they expect you to do that yourself usually....
    Kenwood KDC-X991
    Sundown SAE-100.4
    Sundown SAZ-2000D
    Oct 2008
    SC
    514
    1 Post(s)
    yea i dig it, great job.
    ok how would i change the port location? i would like to put it center on the back wall of the box, (subs forward, port up)
    Oct 2008
    SC
    514
    1 Post(s)
    ok okok so 16^2in port area, per ^3ft. soo in the middle, back wall, 8x20 slot, 26.84" long? does that sound right? to be tuned to 30 hz
    10 cubes net. w*d*H (60)(20)(23) = 13.53^3ft (box)(gross)
    Nov 2005
    Monroe City, IN
    38
    377
    1 Post(s)
    The only way the port can go in the center of the box is if the box itself is deep enough to fit the entire length of the port or to bend the port back on itself once or twice to fit the entire length.... Either one is talking a complete redesign of the enclosure or at least one unusually shaped box.....
    Now if you don't mind the port being off to one side and still up just rotate the orientation of the box and mount the subs accordingly..... but centering the port isn't simple, not that its impossible it entirely is just not simple to do, unless the box is deep enough to fit the length straight into the box like one would do with a round/square port.....
    Kenwood KDC-X991
    Sundown SAE-100.4
    Sundown SAZ-2000D
    Oct 2008
    SC
    514
    1 Post(s)
    how about round ports? aeroports? whats the difference between that and slot ports?
  9. #9
    Oct 2008
    SC
    514
    1 Post(s)
    yeah its, just i want the subs, each directly behind a seat (driver, and passenger) but if the port is to one side, on sub will be wayy more centered. if they were up facing, then it wouldn't be a problem.
    but up facing i was told wasn't that great sounding. is there a way i can make the port not as wide, but longer?
  10. #10
    Oct 2008
    SC
    514
    1 Post(s)
    worst case (which isn't bad) id could just put both subs as close to center, so the port isn't in the way.
