So my port is 10x18.5... How big of a 45 you guys think i should do? 7? 8 mabie?
REFS EATank wu501 connersdad19 Team H&K IbSlamn ShiningBuick FasFocus00(x2) bubbagumper6 01 S 10 zfrerichs tv559 BlimBlam Ebay(280+)
Alarm Prestige APS997A 2-Way/Remote Start
Deck Pioneer AVH-6300BT
Subs 2 DC Lv4XL 18s Off 2 Sundown Saz1500s
Speakers Cliff Designs All Around
Speaker Amps Kicker zx350.4 and zx200.2
Electrical Scorpion 1/0 Wire 2 Pos 2 Neg Runs, Knu 1/0 Flex to Amps, Big 3, Knu Karma RCAs
Batts - Front Deka IntiminatorBack 2 C&D Technologies 12-540FR
Assuming your port is 10 wide, I'd do your 45 piece sqrt(200) inches long, or a hair over 14" long at the widest part.
Huh? Ya 10" tall and 18.5" wide... 185 sqin port
ho w long is the port LV???
feedback thread
http://www.caraudio.com/forum/showth...appa5+feedback
lol the moderators here are GODS word to the wise
"don't cross them lol
20 down and is gonna be 1" over... 35.88 hz
I say just don't do one.
Ben Hemp
1992 GMC Sonoma Ext Cab NEW BUILD
2008 MECA S1 KY State Champion, 151.0 dB
2008 MECA S1 WorldChampion, 151.8 dB
2010 MECA scores: 150.9 dB S2, 151.6 dB S3
Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
no need 4 the 45
feedback thread
Really no 45? Subs up port up on this one... Port is in the middle of 2 18's firing off back glass
Don't worry about it unless you're competing.
One thing that you got to keep in the back of your mind, which a lot of the newer guys on this site don't understand, is that corners are not always a good thing. Corners can often times cause you to lose output. If you look at the inside of a serious competitors spl box, you will not see a 45 degree corner in every corner of the box. This is stuff that you have to test with a Termlab, so unless you're competing then it's really a waste of time. You will not hear a difference.
Ben Hemp
45s offer more than just tenths of a dB to your peak. They help even out pressure transfer and prevent corner loading in the enclosure (which can help or hurt peak output just like you said) which can help smooth out your total frequency response. They aren't just for trying to increase some meaningless single frequency. Corner loading can be great in an enclosure if you use it to drive the port for competitions but that will almost always make the response peaky which may not be desirable for daily setups.
If you want to put a 45 in your port corner, 8.25" is what will work to keep the port width at 10" through the majority of the corner.
Bookmarks
