Results 1 to 7 of 7
Reload Thread: 90 Degree turns with round ports?
    Eddie Havok's Avatar
    Eddie Havok is offline CarAudio.com Elite
    Jun 2008
    new york
    504
    i need my ports to be 22" long, but my box is only 17" high. how would i go about putting a 90 degree turn in them? anyone know where they sell 8" elbows?
    HU-Eclipse AVN5510
    Mids- 8 Audiopipe amb6
    Mid amp- Arc Audio 300.2
    Tweets- 6 Selenium ST200
    Tweet Amp- Arc Audio 300.2
    Subs- (2) 18" sundown nightshades 10cf @ 36htz
    Sub Amp- (2) Audiopipe 30001d
    Alt- 220amp mechman
    Batteries-(3) C&D 100ah
    NW in a trunk car.
    Jul 2009
    Firehouse
    36
    Re: 90 Degree turns with round ports?
    try a plumbing supply store
    l7runner's Avatar
    l7runner is offline Amidst the Static
    Jan 2008
    NC
    1,007
    thats probably gonna cost you a pretty penny. 6" elbows are like $25+
    but an industrial scale plumbing store would be the way to go.
    You can always have your port stick out of the box
    HU: Pioneer 880-prs
    Mid/High Amp: MB Quart DSC4125
    Front Stage: PG mids/Vifa tweets running active
    Sub Amp: DD Z1
    Sub: 10" Mach 5 SPL/Hybrid 1.25ft^3 @ 38hz
    DC Power Alt
    altoncustomtech's Avatar
    altoncustomtech is offline SQ or BUST
    Nov 2005
    Monroe City, IN
    33
    385
    a slot port may be the better answer...... or more ports of a smaller diameter?
    -={1998 Chevy Venture Van}=-
    Kenwood KDC-X991
    Hifonics AS62Ci 6.5" Components front/rear
    Hifonics ZXi6006 <-- Looking for a good deal on a SAE-100.4
    2 new Fi 12 Q's with BP ARRIVED, building enclosure -- ALMOST DONE, needs painted!!!
    Hifonics BXi2006D <-- Looking for a good deal on an SAZ-2000D
    Stinger 0 AWG wiring
    Quick Start Extreme Duty 250A Alternator
    RAAMat BXT60 doors & floors
    Optima RED Top (2)
    2AWG BIG 3
    REFS -- Bought From: TV559
    The Box Calculator Thread -- http://www.caraudio.com/forum/showthread.php?t=444796
    My Build LOG -- http://www.caraudio.com/forum/showthread.php?t=432251
    Link to TWEETER saving Info -- http://www.caraudio.com/forum/showthread.php?t=431342
    Jun 2008
    new york
    504
    i only have a one inch gap from the top of the box to my trunk, so external ports are out of the question. slot port also, its a mini wall type thing, so the trunk is sealed from the car, and i had just enough space to fit the subs, no room for the 150" of port i need. was thinking about doing a slot thru the rear deck, but the subs are in the way. using 2 8" now, but i can't stand having a setup thats not as good as it could be you know.
    smaller ports seem weird, i would need like 6 6" ports for 150" of port right?
    would i be able to like cut a sono tube at a 90 and glue and tape them to all hell together? i would build a brace for them and im sure i could get them sealed, but would the sharp angle cause bad port noise or anything?
    HU-Eclipse AVN5510
    Alt- 220amp mechman
    NW in a trunk car.
    l7runner's Avatar
    Jan 2008
    NC
    1,007
    you might have to shrink down the port area some...you can use aeros and reduce the overall port area, thus making them shorter.
    HU: Pioneer 880-prs
    Sub Amp: DD Z1
    DC Power Alt
    Nov 2005
    Monroe City, IN
    33
    385
    Quote Originally Posted by Eddie Havok View Post
    give us some more information on what you're trying to build, I don't see why a slot port would be out of the question when it's properly designed and much easier compared to trying to figure the correct length with the bends in the pipe....... I know exactly what you're wanting to do by sealing the front of your box to the front of your trunk directly behind the back seat, slot ports will still work find in that application it just takes some imagination to get it all right...... give us your dimensions and goals for this build, the subs you plan to use and the air space you're planning for and I bet we can come up with a way to help, slot, round or square......
    Kenwood KDC-X991
    Optima RED Top (2)
    2AWG BIG 3
