Results 1 to 8 of 8
Reload Thread: question for ported box
    jinx8402's Avatar
    jinx8402 is offline Senior VIP Member
    Jan 2002
    RI
    174
    I am going to make a new box for my 2 12" kappa perfects, I already have the size and tuning all set. My question is that I wanna put the port in the middle of the box, but the box is not deep enough. i will be making a rectangular port and i know i can bend the port, which leads to my question....can i make the port like a "T" and have two openings? or is this a bad idea? If you need a picture I will make one in paint or something
    LoneRanger's Avatar
    LoneRanger is offline Old Yamahas Give Me Wood
    Dec 2001
    Wellston, Ohio
    35
    1,379
    Re: question for ported box
    Quote Originally Posted by jinx8402
    You'll either have to put the port on the side of the box or raise the tuning frequency enough to make it fit. You can also use round ports and use elbows to make them bend. Make sure that whatever you decide to do, there is an equal amount of distance from the port to the back wall as the width of the port.
    "There is no 'I' in Tag Team"
    Project 'rex: Coming Soon to An Eardrum Near You
    jinx8402's Avatar
    Jan 2002
    RI
    174
    so, i can't put the port down the center and have like a T shaped port with two openings? Here is a picture, the first drawing is what I want to do, the second is another option. the shaded area is the port. The reason I want the port in the middle is because my back seat only has the center that folds down, so I want the port to fire right into my cabin. the rest of the trunk will be sealed of (sort of)
    LoneRanger's Avatar
    Dec 2001
    Wellston, Ohio
    35
    1,379
    What kind of car do you have?
    Unless that trunk is sealed off like fort knox, there's no need for you to fire the port into the cabin via the folding center. If you build a regular ported box with a side vent, you can just fire the port at the tail lights and keep that hole open.....and something tells me it'll be louder this way
    havoc06's Avatar
    havoc06 is offline The Juggernaut
    Jun 2003
    VA
    36
    461
    no you cant do that..because when the subs unload..they will be going out both openings of the T. It will sound absolutley terrible and probably damage your subs..if you need to bend the port...use one of the sides of the box...if you want it in the center...make the port area small enough to where you dont have to bend it...but not to small now...always stay with about a 1:9 ratio on ports
    xploder's Avatar
    xploder is offline Junior Member
    Oct 2003
    CA
    44
    why don't you put a smaller diameter port which usually means the length gets shorter at the same frequency.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Personally I like the "T" idea. But in the case your talking I don't think it will work unless you modify it. For number's sake, let's say your using a 1" wide port. Have your "T" part the goes parallel with the back 1" and the part that comes to the front of the box like 2.75" (1" port for each side and .75" for the divider in the middle.) What I' saying is simply split the part that comes foward in half...so really you have 2 "L" shaped ports that share the same wall when the get to the part that comes foward. (1st pic) You could even have the using the back wall of the box. (2nd pic)This will divide the box into seperate chambers though...I don't know if you want that.
    Attached Thumbnails Attached Thumbnails question for ported box-1.jpg   question for ported box-2.jpg
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    jinx8402's Avatar
    Jan 2002
    RI
    174
    Well i got it all figured out. I'm not going with the T shape anymore. I am making the box a little bit bigger and tuning just a bit higher. This will give me enough room. Thanks for the info though, thats why asked to get opinions on how it would sound.
  1. RE box question
    By bumpin_8605 in forum Enclosure Design & Construction Help
    Last Post: 09-24-2003, 10:55 PM
  2. Working on box theories.. Help me out.
    By Silica in forum Enclosure Design & Construction Help
    Last Post: 09-17-2003, 01:41 AM
  3. How do i calculate the box volume for an odd shaped box?
    By AlpineR18 in forum Enclosure Design & Construction Help
    Last Post: 09-13-2003, 05:38 PM
  4. box volume?
    By vod88 in forum Enclosure Design & Construction Help
    Last Post: 09-13-2003, 02:25 AM
