Results 1 to 5 of 5
Reload Thread: Jmac, help with ft^3 calculations
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    29
    16,626
    20
    28 Post(s)
    Hey, i've tried a couple different calculators and i keep getting different numbers as to the cubic feet of the box. If someone else can try and get me a number, that would be sweet
    Width: 50"
    Height: 20"
    Depth 1: 4"
    Depth 2: 6"
    At one place i got 1.7 cubes, and another i got 2.2 cubes.
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    29
    16,626
    20
    28 Post(s)
    Re: Jmac, help with ft^3 calculations
    Yeah, 3/4" MDF. I figured it was less that 2 cubes too, but that other site said 2.2. Do you think that is enough to port it and still have it sound good?
    BTW, why did you use 2 different calculations? Can't you just use one? Oh, and there is another part of the box that the sub is attached to. It's dimensions are
    Length-16"
    Height-22.25"
    Depth 1-3"
    Depth 2-.75"(look in my gallery to understand that, that number is just the thickness of the wood because the top depth is inside the box)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    29
    16,626
    20
    28 Post(s)
    Quote Originally Posted by Jmac
    1.5" x 14.5" x 20.75" x 0.5 / 1728 = 0.13059 ft^3
    1.81734 + 0.13059 = 1.94793 ft^3
    Porting that will be difficult, but achievable ...
    Is it even worth porting? And if it is, 35 hz would be good right? What would the port dimensions be.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    29
    16,626
    20
    28 Post(s)
    Is there much room to port off to the side or does it take up the full width of your cabin ?
    I was thinking several 2" ports out the top, but that's not looking too good ...
    No, it'd have to be ported out of the top. That is the only side that isn't blocked. What about one long port across the top? You looked at the picture of the box in my gallery right?
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    29
    16,626
    20
    28 Post(s)
    Well, i definitely dont want port noise, and there is no way i'm building a different enclosure(at least for now). That design is the biggest box i can fit.
    There really is no way to make a long enough port? D*mn.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team Audio Technix
    Team B2 Audio
    Team Mechman
  1. Somebody Please...jmac Look At This
    By Alpine4life in forum Amplifiers
    Last Post: 10-17-2003, 02:09 AM
  2. 2 ft^3 enough for 12 xxx?
    By LuNaTiC in forum Subwoofers
    Last Post: 09-27-2003, 05:07 PM
  3. for the att of jmac
    By ranger2950 in forum Enclosure Design & Construction Help
    Last Post: 09-25-2003, 01:50 PM
  4. for the att of jmac pls.
    By ranger2950 in forum Subwoofers
    Last Post: 09-25-2003, 11:14 AM
