Need a design for 2 15" RE SE's
Max dims are
W-39
H-19
D-26
Wanna go subs forward port up.
Max dims are
W-39
H-19
D-26
Keep up on car audio news @ www.newcaraudio.net
pm me i'll do you one up
Why subs forward with port up in an SUV? Subs up with port back or at least port to the side would be way better. Also... I'm not sure if you're going to have enough volume with those dimensions but let me go calculate some stuff real quick.
Nevermind, you'll have enough room for a solid 3.5 cubes per sub with 100+ sq. in of port area tuned in the low 30's.
im so not smart enough to do that
p.s. dnick is right(as usual) bout subs up port back
Sure you are. Try. It's all written out.....I think.
It's not as hard as it looks. If you know how to do basic algebra then all you have to do is remember the formula. Then you don't need a program to do anything for you. Plus, doing it on paper is 1000x faster.
How long does it take you to use the 3 programs to design a box? I can use this in under 5 minutes.
Bookmarks
