I heard that you should place your port on the same side as the subs.. Why is this..? But then I heard, it is all good unless you can see your subs through the port.. Does it cancel it out or somthing..?![]()
'93 Corrado SLC
Alpine .. SI .. Adire .. Orion .. Optima .. KnuKonceptz
A port is a port. Doesn't matter where you put it, it'll do the same thing.Originally Posted by n0ftInc
"There is no 'I' in Tag Team"
Project 'rex: Coming Soon to An Eardrum Near You
Well my subs are MUCH louder when facing the back (sealed), does this mean that i should face the port back also??
Yup.Originally Posted by Deven_1313
I just finished my daily driver box. The sub fires up into the lid of the trunk, and the port fires back toward the tail lights.......hellawang![]()
what if I were to put the ports through my rear deck so the bass guys directly into the cabin? would that not work? Because my trunk is a tank, and my rear deck rattles like a mother...I was thinking this would bypass the rear deck canceling the rattles and then it won't have to fight the solidness of the trunk.
2000 black Audi A6 2.8
stock components
RE HC15"
tsunami 1100d (kills kids)
building a 4^3cuft tuned to mid 30's
some nasty sauce mixed in there.
AIM - fincorny82 2000
E-mail - l0mbardo@hotmail.com
firing the ports in teh same direction is only imperitive when doing high spl applications...just getting the back and front waves as close together as possible. But as far as daily driving, any way you fire it will be ok
Originally Posted by havoc06
I don't think it really makes much of a difference unless you've got some sort of crazy box up your sleeve......
Remember the old CRX box? One of the best SPL monsters out there....the subs fired up and the ports fired back....oh wait....i just told on myself![]()
Originally Posted by lombardo
I'm eventually going to build a box like that... by eventually I mean in about 2 months when I get my discount from work so I can guy a 2000w Audiobahn amp for cheap.
1995 Camry LE 4 Cylinder Automatic Sedan
Green Silver Pearl Metallic Clearcoat and/or Silverleaf Metallic
No performance mods
Clear bumper lights
Clarion DXZ835MP
Boston Acoustics ProSeries 6.53 in doors and Q-Logic kicks
Polk/Momo 4 channel amp
Would be EDIT: But I don't think I'll be able to put the sub in the same direction as the ports because my box dimensions will be 40" wide, 11" deep and 17" tall. Because the top is only 11" in one dimension I don't think I'd be able to fit the 12" sub there.
No performance mods
Clear bumper lights
Clarion DXZ835MP
Bookmarks
