Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Reload Thread: Port placement question
    gearhound17's Avatar
    gearhound17 is offline Senior VIP Member
    Apr 2009
    next door to you
    164
    I am in the middle of putting together my new ported box for my RE SE's.
    I am using Re's box designer.
    I want to run sub forward/port up.
    My question is does the L shaped port always need to be aligned the same way in relation to the subs?
    As in the L shaped port is always oriented the same way with the subs?
    I dont think I can add the port to the top of the box and fire the subs forward. Or can I?
    Man I better slow down or I am going to confuse myself...
    Please let me know.
    Thanks guys.
    Head Unit: Alpine CDA-9887
    Front Stage: MB Quart RCE-216
    RF 160.4 Bridged
    Sundown SAE-1200D
    2 RE SE 12 D4's
    Big 3
    Optima Red Top
    Bought from:
    bballer123, wgsj_fortvalley
    Sold to:
    DaBeholder
    krainium's Avatar
    krainium is offline Senior VIP Member
    May 2009
    Stuart,Floriduh
    222
    Re: Port placement question
    No difference.
    dman4486's Avatar
    dman4486 is offline Paid to Post
    Jan 2008
    Central, SC
    9,321
    it can be done...
    Auto: 96 honda passport 3.2L v6 4X4 5sp
    Big 3 pics--THE MAV--THE RSD's--MY VLX
    Rices Creek Pics
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
    PIITB Wut Wut's Avatar
    PIITB Wut Wut is offline He's a Hero
    Jan 2009
    DFW
    3,076
    its done all the time.......
    REFS - ssackett(BFx3), tc3k101(ST),Xtek (ST), MonkeyBone (ST), ***_gobblin(ST), DBBOOM(BF), 1ndatrunk(ST), bsean63 (ST), ls2poweredgoat(BF x2), bones22(BF), Team H&K(BF x5), 18inchjeepin(BF), ProjectPechkin(ST), BushJ311(BF), Rxzilla(BF x3), Doingstuffwell (BF), Twisted_0912(ST x3), Red97Stang(ST), Korn4life(BF), Deafdreamz aka Jacob Perry (BF), tahoebrotha(bf), Deafwish(bf), fasfocus00(BF), ssackett(BFx3), tc3k101(ST), Linkz(ST), skmfkr(ST), Kern417(ST), SSS 18734 (ST), amcreynolds3(ST), RAB (BF)
    I'm not adding any more names
    Apr 2009
    next door to you
    164
    Ok guys.
    Thanks for the fast responses!
    RF 160.4 Bridged
    Sundown SAE-1200D
    2 RE SE 12 D4's
    Big 3
    Optima Red Top
    Bought from:
    Sold to:
    DaBeholder
    Apr 2009
    next door to you
    164
    I know you guys said it would work but please check these pics out.
    I am ready to glue and assemble but need to be absolutely sure this port set up will not create any problems.
    And yes the top panel is a bit short. Will fix that later on during assembly.
    First pic is with port installed. On right side of pic will be where subs are mounted.
    This second one is the top installed. You can see how port sits inside when top is on.
    RF 160.4 Bridged
    Sundown SAE-1200D
    2 RE SE 12 D4's
    Big 3
    Optima Red Top
    Bought from:
    Sold to:
    DaBeholder
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    8,651
    23 Post(s)
    If you mount that board as it's shown you will lose the effectiveness of the length after the bend.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
    krainium's Avatar
    May 2009
    Stuart,Floriduh
    222
    No that will not work
  9. #9
    Mar 2009
    Oklahoma
    1,733
    Quote Originally Posted by ciaonzo View Post
    x2
  10. #10
    Apr 2009
    next door to you
    164
    So what can I do to fix it?
    I have plenty of mdf.
    So it looks to me as if the L shaped port will need to be attached to the top.
    So port attached to top and subs forward.
    How do I use RE's calculator to change the size of my port since my ports I just cut are shorter than the width of the top?
    RF 160.4 Bridged
    Sundown SAE-1200D
    2 RE SE 12 D4's
    Big 3
    Optima Red Top
    Bought from:
    Sold to:
    DaBeholder
  11. #11
    ciaonzo's Avatar
    Feb 2009
    WI
    8,651
    23 Post(s)
    Just keep the partitions in place that are for the port, make a new top without a hole for the vent opening, and shorten the length for the board that will have the drivers mounted to it. So you'll have the drivers and the vent opening/terminus on the same side.
  12. #12
    Apr 2009
    next door to you
    164
    That was how I had it originally.
    So how does someone do subs forward/port top with a rectangular vent?
    I would prefer the port be the only thing seen not the port and subs.
    RF 160.4 Bridged
    Sundown SAE-1200D
    2 RE SE 12 D4's
    Big 3
    Optima Red Top
    Bought from:
    Sold to:
    DaBeholder
  13. #13
    ciaonzo's Avatar
    Feb 2009
    WI
    8,651
    23 Post(s)
    Quote Originally Posted by gearhound17 View Post
    In this case you would need to make the enclosure a bit taller/deeper (whichever the case may be) to allow for the motors to clear the vent partitions.
  14. #14
    krainium's Avatar
    May 2009
    Stuart,Floriduh
    222
    What ever your port area is now make it the same on the the top and keep your port length the same.
  15. #15
    G.W.Kush's Avatar
    G.W.Kush is offline Banned
    Jun 2009
    Canada
    24
    1,048
    umm....
    i think that port....opening....is
    dude honestly WTF.
    i think you totally ****ed up your box with this "top port" of yours
    the port length.....
    amagad this is the funniest **** ive seen in a long time
