Results 1 to 9 of 9
Reload Thread: How To: Design a ported box using pencil & paper
    thehardknoxlife's Avatar
    thehardknoxlife is offline CarAudio.com Veteran
    Sep 2005
    Knoxville, TN
    2,807
    71 Post(s)
    Things you will need:
    Pencil
    Paper
    Calculator
    I worked each equation step by step to help you guys understand. It's actually rather easy. This will be more accurate than the box calculators online. Feel free to correct any mistakes I made.
    There are a few different equations to determine port length. They can be found on numerous sites. I use the following.
    This one comes from a loudspeaker cookbook I read once upon a time. It also can be found online at numerous sites.
    Lv= {(14630000 x R) / (Fb) x [(Vb/Np) x 1728]} - 1.463 x R
    Lv= Port Length (inches)
    Fb= Tune Frequency (Hertz)
    R= See ******* (this will use different equations depending on round or square vents)
    Vb= total internal airspace (cubic ft)
    Np= Number of ports
    ******This is for square vents and will take place of R.
    R= √[( H x W) / π]
    √= square root
    H= height of port (inches)
    W= width of port (inches)
    π = 3.141592 (pi)
    ******This is for round vents and will take place of R
    R= (Dia / 2)
    Dia= Vent Diameter
    This is just an example for a 6" port.
    R= (Dia / 2)
    R= (6 / 2)
    R= 3
    Here we go. The box I want is 6 cubic ft. tuned to 40hz, so lets fill in what we already know. I'll be using a square vent.
    Lv=?
    Fb=40
    R=?
    Vb=6
    Lets solve for R. This is a square so we use the asterisk for a square vent. The vent of my box is going to be 15.5" x 8", (these
    numbers are up to you, multiplying these numbers together determines your port area in inches, which is a number we don't need
    but will help in deciding how big to make the port).
    R= √[(H x W) / π]
    √= square root
    H= 15.5 (inches)
    W= 8 (inches)
    π = 3.141592 (pi)
    R= √[(15.5 x 8) / 3.141592]
    R= √[124 / 3.141592]
    R= √39.470434098380693610118691415053
    R= 6.282549967837955334674739903437
    Now let's fill in the rest of the equation and solve.
    Lv=?
    Fb=40
    R=6.282549967837955334674739903437
    Vb=6
    Lv = {(14630000 x 6.28254996783795533467473990343700)/ (40) x [(6 / 1) x 1728]} - 1.463 x 6.28254996783795533467473990343700
    Lv= {14630000 x 39.470434098380693610118691415053) / 1600 x [6 x 1728]} - 9.1913706029469286546291444787283
    Lv= {577452450.85930954751603645540223 / 1600 x 10368} - 9.1913706029469286546291444787283
    Lv= {577452450.85930954751603645540223 / 16588800} - 9.1913706029469286546291444787283
    Lv= 34.809778335944103703464774751774 - 9.1913706029469286546291444787283
    Lv= 25.618407732997175048835630273042
    There we have it, my port will be 25.6" long.
    Now to figure the box to acquire this port. First let's find how much air displacement this port has. We're assuming the box
    has the port in the middle so we add wood thickness to the port width twice because of the walls found inside the box, the
    top and bottom of the port are part of the outer walls resulting in no displacement for those. This will change depending
    on how your port is. You should be able to figure out where you should and shouldn't need to add wood thickness in the
    following equation. We also assume we're using 3/4" mdf for the wood.
    Dp = {[Lv x (Ph + wt + wt)] x [(Pw + Wt + Wt)] / 1728} x Np
    Dp= Port displacement (cubic ft)
    Pw= Port width (inches)
    Lv= Port length (inches)
    Ph= Port height (inches)
    Wt= wood thickness (inches)
    Np= number of ports
    Dp= ? (cubic ft)
    Pw= 8 (inches)
    Lv= 25.6 (inches)
    Ph= 15.5 (inches)
    Wt= .75 (inches)
    Np= 1
    Dp = {[25.6 x (15.5 + 0 + 0)] x [(8 + .75 + .75)] / 1728} x 1
    Dp = {[25.6 x 15.5] x [9.5] / 1728} x 1
    Dp = {395.25 x 9.5 / 1728} x 1
    Dp = {3754.875 / 1728} x 1
    Dp = 2.1729600694444444444444444444444 x 1
    The equation for figuring out the displacement of round vents is as follows.
    Dp = {[(R x π) x Lv] / 1728} x Np
    R= Radius of Vent (inches)
    π= 3.14592 (pi)
    Np= Number of ports
    This is just an example for 2 6" ports 17" long.
    R= 3 (inches)
    π= 3.14592 (pi)
    Lv= 17 (inches)
    Np= 2
    Dp = {[(3 x 3.14592) x 17] / 1728} x 2
    Dp = {[(9 x 3.14592) x 17] / 1728} x 2
    Dp = {[28.31328 x 17] / 1728} x 2
    Dp = {481.32576 / 1728} x 2
    Dp = .278545 x 2
    Dp = 0.55709
    Now lets make the box. My maximum dimensions are 35 x 30 x 17 (L x W x H) I only need to solve
    for one side so pick one and go with it. I'll pick the width and use the following equation.
    W = {(Dp + Vb + Sw + Ex) x 1728 / [L - (wt x 2)] x [(H - (wt x 2)]} + (wt x 2)
    L= Length (inches)
    W= Width (inches)
    H= Height (inches)
    Ex= Extra displacements: braces, dope, guns, whatever etc. (cubic ft.)
    Vb= Total internal airspace (cubic ft)
    Sw= Subwoofer displacement (cubic ft)
    We already know most of it so let's fill it in and solve it. You can find subwoofer displacement
    by looking at the T/S parameters usually listed as Vd.
    W = {(Dp + Vb + Sw + Ex) x 1728 / [L - (wt x 2)] x [(H - (wt x 2)]} + wt x 2
    L= 35
    W= ?
    H= 17
    Dp= 2.1729600694444444444444444444444
    Vb= 6
    Sw= .2
    Wt= .75
    Ex= 0
    W = {(2.1729600694444444444444444444444 + 6 + .2 + 0) x 1728 / [35 - (.75 x2 )] x [(17 - (.75 x 2)]} + .75 x2
    W = {8.372960069444444444444444444444 x 1728 / [35 - 1.5] x [17 - 1.5]} + .75 x 2
    W = {14468.474999999999999999999999999 / [33.5 x 15.5]} + 1.5
    w = {14468.474999999999999999999999999 / 519.25} + 1.5
    w = {27.864179104477611940298507462667} + 1.5
    w = 29.364179104477611940298507462667
    That's it, we're done. The box is 17" x 35" x 29.3" with a square port in the center of the box 15.5" x 8" x 25.6"
    The formulas to remember:
    Vent Length
    __________________________________________________ ________________________________________
    Np= Number of ports
    R value for Square vent
    R= √[( H x W) / π]
    √= square root
    π = 3.141592 (pi)
    R value for Round vent
    R= (Dia / 2)
    Dia= Vent inside Diameter
    Square vent displacement
    Np= number of ports
    Round vent displacement
    π= 3.14592 (pi)
    Np= Number of ports
    Box Layout
    L= Length (inches)
    W= Width (inches)
    H= Height (inches)
    DNick454's Avatar
    DNick454 is offline Honda + Subs = Rattles :(
    Sep 2008
    Valparaiso, IN
    1,235
    Re: How To: Design a ported box using pencil & paper
    I did very well in calculus thank you very much...
    but I seriously just **** myself. Unless you can write a source code for that and pack it into a nice little program for people to use, then I just can't see it being sought after by very many people. I'm not doubting it's accuracy, I'm just saying it's not exactly "ca.com user friendly". People around here like instant gratification
    ----My Two 10's Flexin' ----
    http://www.youtube.com/watch?v=hLrj5PmrKVM
    Quote Originally Posted by mossberg385t View Post
    im calling goob greedy because the ad revenue was suppost to go to site maintenance and upkeep, i havent seen anything but a slow *** server, a virus, self centered mods, and excuses to be expected from steve meade. I just hope the money is going to a good cause such as a heroin addiction
    I design and build boxes.
    References
    http://www.caraudio.com/forum/showthread.php?t=404022
    91Chevy's Avatar
    91Chevy is offline Resident Metalhead
    Oct 2008
    Vernon, BC
    674
    Quote Originally Posted by DNick454 View Post
    I'll look into writing a program when I get home. Depends whether or not I can remember how And if I still have all my programs etc.
    1991 Chevrolet S10 Tahoe | Extended cab | 4.3L (262ci) V6
    Head Unit: Pioneer DEH-P5100UB
    Wiring: Knu Konceptz Kolossus Fleks 4AWG
    Amplifier: Sundown SAX-100.4 - Shipping as we speak
    Components: Image Dynamics CXS62 V.2 - Shipping as we speak
    Subwoofers: Still need to be ordered
    Toone's Avatar
    Toone is offline CarAudio.com Elite
    Oct 2008
    Detroit,MI
    27
    1,895
    35 Post(s)
    I could work this into an excel formula I might give it a try
    Keep up on car audio news @ www.newcaraudio.net
    Anniku989's Avatar
    Anniku989 is offline Thats what she said
    Oct 2007
    Ohio
    1,656
    That'd be insanely easy to make a little vb prog to do.
    Might actually do it later tonight...
    TEAM CACO
    *Pio 780mp
    *ID CTX65CS
    *Sundown 50.4
    *Hybrid 18" (Treo CSX basket/motor)
    *Sundown 3000d
    *7.5cubes, four 6" aeros
    *2/0 Gauge, Big3
    *Kinetik 1800 x2
    *Mechman alt
    *151.1 tl legal
    Ref's: jailhouseracer8 ; ILoveBass ; bumpincrv ; gordos420 ; 01 S 10 ; riogigalo ; PsychoTheRapist ; blackbonnie ; na_rsx ; 1ndatrunk ; tv559
    headlesskoopa's Avatar
    headlesskoopa is offline Team D.O.A
    Aug 2008
    chicago il
    894
    im
    2008 chevy tahoe
    HU premier 880prs
    2 autoteks mm4000.1 ( both need to be repaired )
    2 sundown saz1500d until other amps get fixed (150.00 sealed legal).
    1 autotek mm100.4
    1 set of comps per front door crunch gp 6.5
    oem in rear
    4 RD alphas v3 18s in a 3rd row wall built by mlstrass
    5 diehard marine batts. 3 in the rear 2 in the front
    dual alt kit by DC power. for now
    2 bottles of super glue for rear view mirror
    91Chevy's Avatar
    Oct 2008
    Vernon, BC
    674
    Quote Originally Posted by Anniku989 View Post
    That's what I was gonna do though
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    OR... you could just use this...
    http://www.caraudio.com/forum/showthread.php?t=215849
    Which is the same thing, but with much less number crunching. We use winISD to do the port length. You could also use the above method with any number of excel spreadsheets...
    It's common sense, simple algebra, and has been type up nearly the same way hundreds of times...
    http://crunktimes.com/ct/
    nG - BSEE
  9. #9
    csu87's Avatar
    csu87 is offline CarAudio.com Veteran
    Mar 2009
    C Springs, CO
    3,696
    143 Post(s)
    too much math involved here. theres a reason i switched from an engineering major to a construction management major.
    but... to the op, good job being able to figure that **** out
    Current - BMW 335xi SQ Build w/ IA and Sundown
    Retired - GMC Jimmy SUBS: 2 12" Aqs SUB AMP: 1 AQ 3500.1 Loudest TL 155.1
    Feedback: MakeshiftAudio, woofercooker, vitveet, jonesy, 2000gator, KickerRex, mathewo, Matt2105, sicaudio, kshutte, coma-toast, RAB, matt2105, jusbloud and more that i cant remember.
