Results 1 to 10 of 10
Reload Thread: running speaker wire out of a wall
    shizzzon's Avatar
    shizzzon is offline Supporting Vendor SPL-Lab
    Apr 2008
    KY
    555
    I have recently been told to use brass bolts...
    Well, i measured the resistance on brass bolts and it came up as high as 0.18 ohms as that would definitely effect power received to subs.
    I am running 4 DC Lvl4 15s and 2 AQ3500ds.
    My idea is to use, for example, 2 1" ID PVC pipes. I use only 8 awg wire. I'd run one set of wire out 1 pipe and the other set of wire out the other pipe. Glue rubber grommets on both ends of each pvc pipe then shoot expanding foam all inside of each pipe and let cure. This should be enough to seal off any air leaks through the pipe and the grommets will help as well. This also has no resistance since it wil be straight ran wire from the subs terminals directly to the amps.
    This method sounds doable correct? Because other people keep telling me to use brass bolts when i just found out how much resistance they actually have.
    Yes, this is a comp build with partial daily.
    National Director of Sales and Tech Support for SPL-Lab USA
    Custom Hobby machinist
    Computer modding\repairing
    Video\Audio Editor
    Hosts the largest collection of test tones in the internet world.
    http://www.spllabusa.com
    Affordable Pressure Meters At Their Best!
    Mar 2009
    Oklahoma
    1,739
    Re: running speaker wire out of a wall
    Did you take into account the resistance of the probes?
    shizzzon's Avatar
    Apr 2008
    KY
    555
    yes i did. Probes were reading 0.25-0.28. Brass bolts were reading 0.4-0.46
    Video\Audio Editor
    perfecxionX's Avatar
    perfecxionX is offline CarAudio.com Veteran
    Dec 2006
    indianapolis
    2,528
    19 Post(s)
    “Ignorance more frequently begets confidence than does knowledge" Charles Darwin
    refs---
    http://www.caraudio.com/forum/showthread.php?t=219529&highlight=perfecxionx
    http://www.caraudio.com/forum/showthread.php?t=259748
    http://www.diymobileaudio.com/forum/itrader.php?u=28091
    http://www.caraudioclassifieds.org/forum/itrader.php?u=916
    http://myworld.ebay.com/perfecxionx/
    dbeez's Avatar
    dbeez is online now CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,776
    51 Post(s)
    use the brass boltts man it will work and always works..many comp guys use that method..
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
    mcbuggin's Avatar
    mcbuggin is offline CarAudio.com Elite
    Feb 2008
    smithfield,UT.
    630
    Quote Originally Posted by dbeez View Post
    X2 that's what i do
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,602
    13 Post(s)
    can also try stainless steel as that's what I normally use...
    shizzzon's Avatar
    Apr 2008
    KY
    555
    i just got a tap n dye set.
    I'm gonna make my own copper all-thread rods.
    Stainless steel is next to the least conductive metal.
    Again, this is for comp use, not daily, so i gotta be an *** about resistance here.
    I'm gonna be stoppin by a couple shops tomorrow to see if they can have or can order me some pure silver bolts, washers, nuts. Lucky try but i got nothing to lose.
    Video\Audio Editor
  9. #9
    theMessenjah44's Avatar
    theMessenjah44 is offline CarAudio.com Elite
    Apr 2009
    Central IL
    1,383
    drill a hole and run the wire straight through the wall then seal it up with resin?
    less connections = better
    Bought from: jamesw, dave_damage, ampjunkielikeme, JuicyJeff
    Sold to: DaBeholder, ampjunkielikeme, ax600, shackel. Worked with Rio
    Team Edge Customs
    Last year: '05 Ford Escape - Alpine 7995 - AllTsunami 1/0 - C&D batt 15" IA Warden (2) Audiopipe AQX-3500.1's at 1/4 ohm 151.3 outlaw
    This year: '92 Mazda 323 - C&D batt Batcap 4k, (6) Powerbass 15's (250rms each) (1) Audiopipe AQX-3500.1's at 1.3 ohm 152 outlaw
    Currently rebuilding Mazda with (4) American Bass HD 15's in a wall, 157?
  10. #10
    shizzzon's Avatar
    Apr 2008
    KY
    555
    well, that's somewhat what i was wanting to do, just straight wire... but everyone else seems using bolts or threaded rod is better so threaded copper rod it is.
    Video\Audio Editor
