Results 1 to 3 of 3
Reload Thread: what to use to cut fiberglass
    jinx8402's Avatar
    jinx8402 is offline Senior VIP Member
    Jan 2002
    RI
    174
    hey, i tried search but didn't come up with the answer i need. can i use a jig saw to cut fiberglass, or no? it may seem like a little dumb question but the reason i'm asking is because i have a jig saw, but don't have a dremel tool. if i can just use the jig, then i won't buy the dremel. thanks
    Q45guy's Avatar
    Q45guy is offline Member
    Jun 2002
    Portland, OR.
    38
    141
    Re: what to use to cut fiberglass
    You can use a jigsaw, but you have to be very careful. Make sure your cutting on something flat like a piece of wood on some sawhorses. Make sure you use a fine tooth blade as well so it doesn't end out cracking the fiberglass. Fiberglass is very fragile along the edges....so don't let the jigsaw shake the edges too much. Remember....let the blade do the cutting and don't force the blade.
    Q45guy
    q45guy@comcast.net
    1991 Infiniti Q45
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    32
    8,480
    32
    It's gonna be difficult to use a jigsaw...it's gonna take a long time, and a lot of patience, and even then, it may not turn out the way you like. A dremel makes it about 1000 times easier.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
  1. Can u may a ported fiberglass box???
    By DbRufus1234 in forum Enclosure Design & Construction Help
    Last Post: 02-03-2004, 02:25 AM
  2. check out my fiberglass box *PIC*
    By subboxmaker in forum Enclosure Design & Construction Help
    Last Post: 01-31-2004, 02:14 AM
  3. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 12:08 PM
  4. Slot Ports and Fiberglass
    By venom107 in forum Enclosure Design & Construction Help
    Last Post: 07-29-2003, 10:47 PM
  5. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
