Results 1 to 6 of 6
Reload Thread: Small box shape: Irregular OK?
    drpeeb's Avatar
    drpeeb is offline ...
    Apr 2009
    FL
    466
    I have very little room to work with in my extended cab truck, but am trying my best to design my box to meet Kicker's recommended "sealed" dimension of 1.0 cubic foot.
    I can accomplish it with some odd little shapes sticking out here and there ... Will odd little shapes affect the sound in a bad way??
    (I've tried placing my current rectangular prototype box on the seat rather than under it on the floor, and the bass is way better sounding when it's on the floor facing up)
    Tks
    I have nothing to say in this signature space.
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    35
    13,103
    21 Post(s)
    Villeza1's Avatar
    Villeza1 is offline Night Ryder
    Mar 2009
    Valdosta, GA
    1,996
    215 Post(s)
    Re: Small box shape: Irregular OK?
    Quote Originally Posted by iamamp3pimp View Post
    it should be fine.
    make sure its sealed well though
    X2
    2 AB 1100.1's
    4 Tantric Sounds SHD 18's
    Team Tantric Sounds
    drpeeb's Avatar
    Apr 2009
    FL
    466
    Quote Originally Posted by Villeza1 View Post
    X2
    OK ... thanks to both.
    Alex JB's Avatar
    Alex JB is offline Senior VIP Member
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    you thinking of fibreglass or just odd angle wood work?
    if you can save yourself a load of work by only getting 0.9 cu-ft them you can use some wading to artificially make the box seem bigger.
    I managed to squeeze 1.1 cu-ft after port and bracing in my F150 ext cab so you should be able to get 1 cube sealed
    JL 6.5's in the front doors
    AP1040 bridged driving them.
    2 Sundown E8's in 1.1cu ft tuned to 30Hz.
    700rms @ 2Ohm Cadence... let's see what the the E8's can take
    drpeeb's Avatar
    Apr 2009
    FL
    466
    Quote Originally Posted by Alex JB View Post
    I'm just using 3/4" MDF. Never tried fiberglass, & not really ready to, yet.
    Yeah, I can get it to about 0.9 cu-ft (without a bunch of weird extra shapes) which is probably good enough. But I'm also wanting to make a ported version which Kicker says should be a minimum of 1.25 cu-ft plus the port .. Gettin' big. May just not be able to do that one.
    My 0.9 cu-ft version is very shallow, though, with the back of the speaker within about 3/4" of the rear (bottom in this case) panel. Is there any limitation on how close the back of the sub should be kept from the panel behind it??
