Results 1 to 9 of 9
Reload Thread: box material
    dreamer33917's Avatar
    dreamer33917 is offline Junior Member
    Apr 2009
    ft myers beach fl
    29
    box material
    as far as sound quality goes would a sub box made out of Plexiglas, acrylic,or lexan affect it? i was thinking about fiberglass also but i don't know ? is sound quality effected with these different materials versus your typical mdf or wood box
    fbi90909's Avatar
    fbi90909 is offline Panty Thief
    Jun 2006
    Key West, FL
    30
    7,772
    Re: box material
    are you looking at a 100% enclosure made of a different material other than MDF?
    i will not put **** or outside links in my signature again. if i do i will be banned. all hail the moderators.
    DNick454's Avatar
    DNick454 is offline Honda + Subs = Rattles :(
    Sep 2008
    Valparaiso, IN
    1,243
    Re: box material
    It would be really hard to build an entire box out of those materials. However, building a box out of MDF and then leaving a window open and covering it with lexan for a see-thru beauty panel to the subs would work and has been done. Then you can put some L.E.D.s or some lights in there and what not if you're going for a show-car like look.
    ----My Two 10's Flexin' ----
    http://www.youtube.com/watch?v=hLrj5PmrKVM
    Quote Originally Posted by mossberg385t View Post
    im calling goob greedy because the ad revenue was suppost to go to site maintenance and upkeep, i havent seen anything but a slow *** server, a virus, self centered mods, and excuses to be expected from steve meade. I just hope the money is going to a good cause such as a heroin addiction
    I design and build boxes.
    References
    http://www.caraudio.com/forum/showthread.php?t=404022
    Apr 2009
    ft myers beach fl
    29
    Re: box material
    this the link to a box builder in cali they are acrylic and just bad as* please check them out www.gatelyaudio.com there boxes will win you a trophy
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    40
    14,802
    Re: box material
    gately makes some serious boxes but they are expensive as all get-out.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    gotparts90's Avatar
    gotparts90 is offline CarAudio.com Elite
    Jan 2008
    chicago
    1,681
    Re: box material
    after you cut it don't forget to flame the edge a little to make it clear again. just go light with the torch and it will go from the rough white right back to clear. I have used close cell acrylic before and it worked well glued together nice but used that just because my friend had lots for fish filter making. they sent him an order of to thick of material and I used it for a box. you better have a good straight cutting saw.
    O my liver!!!!!!!!!!!!!!!!!!!
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    Re: box material
    the glue used, doesnt it actually melt the edges together?
    you may also need to acquire a plexiglas bender, not cheap either.
    fiberglass is good, and for the most part, they all sound the same. the only time youll notice a difference in sound is if you have large panels flexing....
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
    gotparts90's Avatar
    Jan 2008
    chicago
    1,681
    Re: box material
    yes it is a chemical bond the plastic does "melt" very strong bond like when you use model glue
  9. #9
    Apr 2009
    ft myers beach fl
    29
    Re: box material
    well i guess i need to rethink the box then it is way expensive i guess ill have to come up with something else for a wow factor
