Looking for advise on a blowthru design for a 18" RD ALpha , I dont want to stand the sub up, looking for a design that allows horizontal placement . Thanx in advance. mx dm 48w X 17t X ?? D
2000 Expedition
Eclipse CD 5030
2 RD Audio HW GP 18's
1 RD Audio D9's
1 Mechman 250
you're wanting to have an 18" sub... horizontal in a 17" tall space? does this not sound incorrect? do you mean at an angle?
what exact year and model is your truck ?
1972 plymouth valiant lowrider with hydraulics
its bad azz
1990 chevy 2500 single cab / full size bed - lifted on 33s
its currently ugly.
my corvette is sold. what a piece of crap it was
but it did get loud !
whats up with the filter man.. the word a$$ is not a bad word
2000 Expedition
Eclipse CD 5030
1 RD Audio D9's
1 Mechman 250
yes, I believe if you made it at a 45 deg. angle it would probly work out best,
but you would realley have to secure it good with extra bracing so it wont come loose.
if 17" tall is your max demention, id go no larger than 16" tall
because you are going to want to insulate the actual box off of your bed
of the truck or else it will vibrate and create all kinds of racket.
that and if you get a bed top it might also take a tiny bit of space too. ?
its bad azz
its currently ugly.
Just go with 2 15s instead.
yea at an angle facing front and slightly up.
when it comes to rd audio mike465 is the man you need to talk to as he knows there products inside and out....
2002 suburban
Security System Code alarm
Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit pioneer 880prs
Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
Wiring lots of 1/0 stinger, tsunami
Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
Subs 4-18" nightshade v2's d2
System DetailsDaily driver.
What about a 4th order? You could have the sub firing either up or down into a ported chamber and just the port would fire into the cab.
REFERENCES
cam5860, Godsmack, dropkick13, ls2poweredgoat, bunkerking09, ProjectPechkin, GavinVoy, kmanian, magnum21, natetate, gqjeff, mustangowner, ssackett, hazardous0388, Rusty...WCA, ohsosmooth, grassroots, Leister, Scott S, Pyro_by_Nature, teamsolo, jblcamry, pickup1, got_focus?, fasfocus00, Zellner, Goindef154, Darknight, orangelss, Thorshammer1, BigSix
isnt that basicaly a sealed box with a tunnel into the cab ? what is it when there is a port and then ported into the cab ? 6th ?
2000 Expedition
Eclipse CD 5030
1 RD Audio D9's
1 Mechman 250
4th order is sealed chamber firing into a ported chamber and the ported chamber is the only part of the box coming into the cab. I'm not sure if the sealed box tunneling into the cab is considered a 4th order, because that is exactly what I wanted to do but there has to be more to it than that I would think (size of tunnel has to have some effect on sound).
REFERENCES
Bookmarks
