Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: 15" sub bandpass box
    Nov 2008
    Port Orchard, WA
    93
    This is my plans for a bandpass enclosure for a 15" crossfire bmf the sealed portion is 2 cu ft. and the ported part is 3.3 cu ft but i dont know how to figure out the port. the sub calls for a 2 cu ft. sealed enclosure and a 3.15 cu ft ported enclosure. so i figured taking out the port and supports on the ported side it would even out to about 3.15 cu ft. Im using 3/4 in mdf. I dont know whether i want to do a port going into the cabin or facing the cabin or facing the trunk. Im thinking about doing it into the cabin and doing an amp rack behind it. its going into a ford zx2. I dont know how to figure out the size of the port. I was thinkin either using a side for length but I might do cylinder ports into the cabin. Which would sound better square ports or cylinder ports?? Im going for SQ and not so much spl. I was thinking of tuning the box to 30 hz.
    any help appreciated.
    P.S. anyone know of any good box building programs?? Im still using the old school pen, paper, and math skills.
    I do custom fiberglass work.
    feedback: http://www.caraudio.com/forum/showth...63#post6456163
    Bought from: RyanM923, TC2k15x2, _AnGeL_, sundownz, oldschool4me, Toomnymods, ejschultz, JbIrD, TheLow, SPL KID
    Done work for: RidnClean
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    Re: 15" sub bandpass box
    do 3.5 cubes sealed 1.8ported
    and tune ur ported chamber to 50hz
    80
    scottyfkachris's Avatar
    scottyfkachris is offline Member
    Nov 2008
    Port Orchard, WA
    93
    why should the sealed be bigger and the ported be smaller?? and wouldnt 50 be too test tone style?? it is my daily driver and how do you figure out the port size dimensions?
    406er's Avatar
    406er is offline box builder extraordinair
    Sep 2005
    Winnipeg,Mb
    31
    1,043
    you dont know that much about bandpass do ya. also what strikes me as odd is that your goin for SQ and not SPL, wich 90% of bandpass are for SPL aplications. also taking the subs ported and sealed recomended enclosure volumes and putting them together dosnt make it the ideal band pass enclosre volumes. my advice for you is build a seald box or a low tuned ported box for MAX SQ
    Head installer for Hamilton Audio
    Macrom, Stetsom, RD and Sundown car audio
    1999 Jeep Cherokee Sport
    Eclipse CD3100 head unit
    Steg Audio System F4 380 4ch amp
    Macrom M2 6 1/2 comp set
    RE RE 10
    dB set up
    SD3000, SPL12 143.4dB (in my 91 Sonoma)
    http://www.sounddomain.com/ride/759285
    galacticmonkey's Avatar
    galacticmonkey is offline Wants a button like that.
    Sep 2006
    Tampa, FL
    7,697
    4th Orders can sound sick if done right.
    80s design should play REAL smooth.
    80INCHES's Avatar
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    Quote Originally Posted by galacticmonkey View Post
    BINGO!!!!!!!!!!
    u knew exactly wat i was talking about!!!!
    Quote Originally Posted by scottyfkachris View Post
    Quote Originally Posted by 406er View Post
    he wanted something that was more sq not so much spl....thats why i said make the sealed chamber bigger ..and the ported chamber smaller...the bigger the ported chamber the peaker it will be....the smaller the ported chamber the more flat it will play and with a bigger sealed chamber the lows will be really nice...remember 4th order bandpass have the same characteristics as a sealed box the transent response will be very similar..if done right
    80
    Nov 2008
    Port Orchard, WA
    93
    Ya this is my first bandpass enclosure im trying. ive done a couple sealed boxes and one ported box in the past. thanks for all the help. i guessed that the sealed and ported rec. would be the deminsions needed but ill try and figure out the design 80 gave. im still tryin to figure out port deminsions tho. Thanks for the help 80
    Nov 2008
    Port Orchard, WA
    93
    im still lost in trying to figure out the port size deminsions. Im going to try 3.5 sealed and 1.8 ported tuned to 50hz like 80's design. I want to use one or 2 3" pieces of pvc pipe or maybe just one bigger one. Can anyone help me figure out what the port length should be or know of any program that could help me out on this box?
  9. #9
    80INCHES's Avatar
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    use 4 3inch round ports each at 14inches long
    80
  10. #10
    DNick454's Avatar
    DNick454 is offline Honda + Subs = Rattles :(
    Sep 2008
    Valparaiso, IN
    1,243
    Quote Originally Posted by 80INCHES View Post
    BINGO!!!!!!!!!!
    80
    Having the bigger sealed chamber is better for making a flatter response, so listen to 80. If you truly want a bandpass for SQ purposes, that would be a great setup. The nice big sealed chamber will give it great response and woofer cone control down to any frequency and the small ported chamber will keep the bass tight and not sloppy so it should do really well for SQ purposes and still get hella loud.
    ----My Two 10's Flexin' ----
    http://www.youtube.com/watch?v=hLrj5PmrKVM
    Quote Originally Posted by mossberg385t View Post
    im calling goob greedy because the ad revenue was suppost to go to site maintenance and upkeep, i havent seen anything but a slow *** server, a virus, self centered mods, and excuses to be expected from steve meade. I just hope the money is going to a good cause such as a heroin addiction
    I design and build boxes.
    References
    http://www.caraudio.com/forum/showthread.php?t=404022
  11. #11
    Nov 2008
    Port Orchard, WA
    93
    alright thanks guys. ill be starting to build the box either today or tomarrow.
  12. #12
    Nov 2008
    Port Orchard, WA
    93
    heres my new design thanks to the help of 80 for the internal airspace and port demensions.
    what you think?
  13. #13
    dappa5's Avatar
    dappa5 is offline DO WORK! (if u can)
    Mar 2009
    S.W.FL
    1,840
    before you build that box STOP! download sketchup and present a proper drawing lol just playin' gl w/build
    feedback thread
    http://www.caraudio.com/forum/showth...appa5+feedback
    lol the moderators here are GODS word to the wise
    "don't cross them lol
  14. #14
    Fuknmovin's Avatar
    Fuknmovin is offline CarAudio.com Elite
    Nov 2008
    Palm Desert, CA
    591
    Whatever you do.....MAKE SURE you LISTEN to 80, he knows his CHIT! I LOVE my 6th order he designed for me!!!!
    A 10 that thinks it's a 15!
    I build and design boxes! PM me for details..
    bballstarx124x Quote: Got it running today. Sounds amazing! I'm getting a lil windshield flex on only 500 watts!
    Refs: MTX9515, M@nJo, MSW Danny, 95Prober
    http://www.caraudio.com/forum/showthread.php?t=395576"]http://www.caraudio.com/forum/showthread.php?t=395576
    http://www.caraudio.com/forum/showthread.php?t=394806"]http://www.caraudio.com/forum/showthread.php?t=394806
  15. #15
    Nov 2008
    Port Orchard, WA
    93
    box is gonna have to be put on hold. did some more measurements and it is going to have to be permanently built into my trunk. So im gonna wait until i have everything done for the set up. BUT be looking for a build log in a month or so. Thanks for all the help!
