Results 1 to 2 of 2
Reload Thread: Not enough hardener?
    Chris02NeonSXT's Avatar
    Chris02NeonSXT is offline Senior VIP Member
    Aug 2002
    Goshen, NY
    26
    172
    It's been about 3 hours now since I put a coat of resin on my fiberglass box. It still has not hardened. I just finished putting another coat that had a lot more hardener in it, in hopes of speeding up the first coat also. Will this work? I've also made a little "tent" with one of those heaters ppl use for camping in hopes of speeding up the process. Fortunately (I think) these coats are only for finishing purposes, I did not use any mat. So if this stuff never dries is there some way I could take it off?
    Thanks
    Chris
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    30
    1,509
    2 Post(s)
    Re: Not enough hardener?
    mix up another batch with lots of hardener and spread er on, i did the same and it wouldn't cure, so i had to spread a new layer on....
  1. resen and hardener
    By cooldoctorb in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 06:49 AM
