Results 1 to 6 of 6
Reload Thread: 10" Fi BL box. Help please.
    cockeyed00's Avatar
    cockeyed00 is offline Senior VIP Member
    Jan 2003
    Antioch, CA
    272
    I am getting a 10" BL for my truck. It is going behind my rear seats and here are the dimensions: height - 16" top depth - 7" bottom depth - 9" length - 52" (dimensions are from a box I have in there right now running 3 10s. Roughly 2.75 cubes of space with 3/4 mdf) I want to do a slotted or square port if possible, probably on top. On the Fi site it says 1.5 cubes but will a bigger box be better? Any help would be great! Thanks
    HEY LOOK, you dropped your pocket....
    KHARPS's Avatar
    KHARPS is offline CarAudio.com Veteran
    Jul 2008
    IL
    31
    3,332
    Re: 10" Fi BL box. Help please.
    I had one in 1.25 and then 1.5. [email protected] was perfect for it in my opinion.
    REFERENCES
    cam5860, Godsmack, dropkick13, ls2poweredgoat, bunkerking09, ProjectPechkin, GavinVoy, kmanian, magnum21, natetate, gqjeff, mustangowner, ssackett, hazardous0388, Rusty...WCA, ohsosmooth, grassroots, Leister, Scott S, Pyro_by_Nature, teamsolo, jblcamry, pickup1, got_focus?, fasfocus00, Zellner, Goindef154, Darknight, orangelss, Thorshammer1, BigSix
    slam's Avatar
    slam is offline CarAudio.com Veteran
    Oct 2005
    fort worth, tx
    45
    5,470
    52 Post(s)
    had mine like KHARPS and it banged hard
    cockeyed00's Avatar
    Jan 2003
    Antioch, CA
    272
    So there will no benefit to making a bigger box than suggested? Have the space and if I can might as well use it. Any help with a slot port or should I just use a round one?
    azimuth's Avatar
    azimuth is offline funded*by*soros
    Mar 2006
    Denver, Co
    42
    9,053
    9 Post(s)
    Quote Originally Posted by cockeyed00 View Post
    1.5 will work fine. you can use either a round or square port, as long as it's designed correctly, and with enough port area.
    2003 chevy s-10 ext. cab
    hu: jvc kd-avx1
    precision power 356cs components
    front amp: infinity 475a
    sub: diamond audio d6 10d4
    enclosure: 1.1 cubes ported tuned @ 31hz
    sub amp: JL G1700
    DNick454's Avatar
    DNick454 is offline Honda + Subs = Rattles :(
    Sep 2008
    Valparaiso, IN
    1,235
    Stick to what the manufacturer recommends for the volume. Those are the optimal settings for that particular woofer. As for the port style... it really depends what you want to do area, depth, and tuning wise. You may not be able to use a round port since your box isn't all that deep and be able to get enough port area and still have the ports long enough to get the desired tuning. A slot port is nice because it saves internal volume because it utilizes 3 of the already used walls as part of the port and doesn't need any internal bracing like the end of a PVC or aero port would, so it saves space that way. What are your plans for sub and port orientation?
    ----My Two 10's Flexin' ----
    http://www.youtube.com/watch?v=hLrj5PmrKVM
    Quote Originally Posted by mossberg385t View Post
    im calling goob greedy because the ad revenue was suppost to go to site maintenance and upkeep, i havent seen anything but a slow *** server, a virus, self centered mods, and excuses to be expected from steve meade. I just hope the money is going to a good cause such as a heroin addiction
    I design and build boxes.
    References
    http://www.caraudio.com/forum/showthread.php?t=404022
