Results 1 to 7 of 7
Reload Thread: 2 questions...one thread. Formula for Air space in fiberglass enclosures and....
    Sideways17's Avatar
    Sideways17 is offline Member
    Mar 2009
    Franklin Grove, IL
    91
    Questions:
    1) How do I figure airspace in a crazy fiberglass enclosure?
    2) How do I change port tuning on a slot ported box? Every box I've ever built has been by company recommendations for their subs.
    thegreatestpenn's Avatar
    thegreatestpenn is offline lazy genius
    Nov 2007
    columbus
    9,276
    32 Post(s)
    Re: 2 questions...one thread. Formula for Air space in fiberglass enclosures and....
    1) area is always lxwxh or whatever for squares and triangles so if u need to break the box into sections and then calculate separate areas then combine for the total value do that.
    2) u can change tuning by adding chambers to the slot port or extending it
    http://www.caraudio.com/forums/buyer-seller-feedback/401249-thegreatestpenn-feedback-thread.html
    2k2 honda civic
    summer build
    audison sr4 on focal polyglass 165vb components active
    soundstream rubi1.2500d on dc lvl4 xl 18
    pioneer deh-80prs
    squeak12's Avatar
    squeak12 is offline CarAudio.com Veteran
    Apr 2005
    Thomaston, GA
    3,671
    I would fill trash bags with known volumes of packing peanuts, etc. See how many of the known value will fit into the box.
    If everything else remains constant, which will not be the case unless you have external ports:
    Longer Port = Lower Tuning
    Less Port Area = Lower Tuning
    Less Net Volume = Lower Tuning
    Sideways17's Avatar
    Mar 2009
    Franklin Grove, IL
    91
    Quote Originally Posted by squeak12 View Post
    Thats pretty much what I used to do when I worked at the shop. I took cardboard box with a known internal airspace and filled it with packing peanuts. Then I filled in the box. But I didnt know if there was some formula anybody used since I dont have the packing peanuts readily available anymore...I could just get some from them I guess.
    If I slotport that 13W6v2 what should it be tuned at for SQ? 30hz? JL's recommended slot ported box is tuned at 34.5hz. And I dont want to just make that box. I want a custom box Im kinda stuck. Anyone hear a 13W6v2 in a SQ slot ported box? How do I figure the box volume, port area and port length for that sub at 30hz?
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    I like playground sand better than packing peanuts. It gives more accurate numbers
    5 % equipment
    90 % install
    5% beer
    Sideways17's Avatar
    Mar 2009
    Franklin Grove, IL
    91
    Quote Originally Posted by ramos View Post
    Good call man! Never thought of using that. Thanks!
    nineball's Avatar
    nineball is offline too many toys...
    Feb 2008
    home
    1,921
    11 Post(s)
    i use a bean bag chair. they usually have the super small round styrofoam pellets which work better than peanuts, not as fine as sand but much easier to remove. when you are done measuring you just pour them back into the chair and wait til the next use or sew it back up and return it to the store.
    Quote Originally Posted by eharri3 View Post
    I have 4 12s getting 2K watts rms and my front stage is 4 Walmart JVC coaxials running off 16 watts rms of head unit power. My sub sounds fine but my mids and highs don't sound very clear and start to distort long before my subs do. Anybody know why? Any suggestions?
