Results 1 to 6 of 6
Reload Thread: Port correction factor...
    Vageta31's Avatar
    Vageta31 is offline Junior Member
    Aug 2003
    Northern California
    I just read on JL's site about port correction factor so let me see if I'm getting it right. Basically if you use a wall of the enclosure as a side of the port(slot design) then you effectively gain a bit of length to the port? Apparently because one side of the port doesn't end at the same place as the other, the speaker see's this as extra port length, half of the port height to be specific.
    So in essence this can be a bad thing for those tuning higher and don't take it into consideration as it will extend the port and cause the tune to go a bit lower than expected. For those like me however who want to tune low you can use it to your advantage by getting a free inch or so on the port without actually taking up displacement?
    Personally I want to tune my box low, but going as low as I'd like will take up gobs of space that I don't have. So when WinISD tells me to make a port length of 25.25" to accomplish a 29hz tune, then my 2" high slotted port design will add an extra 1" of effective port area giving me 26.25" and tuning a little bit lower? Assuming of course that I ingored the correction factor and built the actual port to 25.25".
    Just making sure I have the basic logic down to decide whether or not to actually build the port without the correction factor or not. If it will cause more harm then I will subtract that inch off of the design. Seems to me like a free way to get a longer port without taking any displacement away. May be miniscule in the larger scheme of things but hey it's free.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Never really looked at it like that. But yeah....makes sence to me. Anyone else have thoughts?
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Jun 2003
    Thief River Falls, MN
    48
    128
    there was a thread at SIN awhile back about this verry thing.
    at the time i did not think about it.
    still have not
    but from what you are saying it makes sense.
    this could be why my note is not as i thought it to be.
    guess i will have to look into that tomorrow when i work on my box.
    Monty
    excelon|PPI|Tsunami|eD|Diamond Audio|peal and seel|
    USACI b-stock 601+ best of 153.3 aiming for 155
    dbdrag street A best of 143.5 on new sensor
    F150Matt's Avatar
    F150Matt is offline Senior VIP Member
    Jul 2002
    Houston, TX
    32
    484
    3 Post(s)
    Use this website, it has a slot vent calculator. Tuning was right on the money last time I used this calculator. http://www.loudspeakers101.com/VentCal1.htm
    Matt Sibley
    Dad, Electrical Engineer, MBA
    Used to do these:
    Team S.P.E.A.D. Captain
    Team Kicker
    Team Maxxsonics
    USACi Pro Stock 5001+ World Record Holder
    slipknot87420's Avatar
    slipknot87420 is offline ^^^^^^420^^^^^^
    Jul 2002
    huntsville alabama
    30
    1,935
    24
    Re: Port correction factor...
    Quote Originally Posted by F150Matt
    NEVER!! use that you're prolly tuned ~10hz higher than it say's
    93 blazer
    Panasonic>>>>Orion>>>>Kicker>>>>Pioneer
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    Re: Re: Port correction factor...
    Quote Originally Posted by slipknot87420
    I have heard of people saying to tune it lower because you will be tuned ~10Hz higher. When I built my box I tuned it so it would peak at 38Hz (in WinISD). When I went to comp. with it I hit my max SPL at 38Hz. I don't know if it has to do with the vehicle or not but my tones were exactly where I tuned them to be.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  1. extreme port?!?
    By yourmomonacid in forum Enclosure Design & Construction Help
    Last Post: 08-18-2003, 12:35 AM
  2. dual 12k slot port help!
    By Q45guy in forum Enclosure Design & Construction Help
    Last Post: 08-15-2003, 09:21 PM
  3. difficult port question>>>>>>>>>>>>>>>>>
    By phoneman in forum Enclosure Design & Construction Help
    Last Post: 08-13-2003, 11:43 PM
  4. slot port
    By jbl_marshall21 in forum Enclosure Design & Construction Help
    Last Post: 08-08-2003, 08:40 PM
  5. How to tune a box?
    By KJL_21 in forum Subwoofers
    Last Post: 08-04-2003, 01:17 AM
