Results 1 to 14 of 14
Reload Thread: precision port 90 degree elbow
    gqjeff's Avatar
    gqjeff is offline Waz up????
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    I got my 4" port today but I need to use a 90. I went and checked out the standard 90 4" pvc ones and they do not fit at all. How or where are people making these work or getting ones that will? I need to use the flare at the end also and I see dayton make a male to female one so is that what I need?
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Re: precision port 90 degree elbow
    Well the Dayton ones will not work just got off the phone with parts-express. So how are you guys sealing them together using standard PVC 4"? Could I use some type of gasget then use plumbers goop or something to fill the void and sill it?
    Thanks, Jeff
    AVX Mike's Avatar
    AVX Mike is offline Senior VIP Member
    Nov 2006
    Waite Park, MN
    40
    391
    3 Post(s)
    I have never had luck putting any angles on thin wall pvc.
    Mike Schwitz
    Installer/ Fabricator
    Audio Video Extremes
    Waite Park, MN
    320-217-5877
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Yea that's what I am afraid of plus the weight of the 4" pvc elbow on the thin wall. How are others doing it?
    18inchjeepin's Avatar
    18inchjeepin is offline CarAudio.com Elite
    Sep 2007
    Muncie, IN
    1,329
    2 Post(s)
    make part of the port outside the box
    Silver HHR - 155.1 db
    TEAM SOUNDSTREAM
    XS Power
    REFS:jeeper07,thegreatestpenn,TeamPSI(x3),dbman150,bad @SS chevy,tommyk90,*GQ*,THXdts, XxSuperAdamxX,fatboyracing,gymfreak101,LTnChynadol l,amartin_72,avs20,Twisted_0912
    SOLD TO: Kold_Killa,GMCJimmyslt2000,skitzafit,ravens9322,wE rd,jeramydean,Shinju,the12voltsux,gammey4,camaroau dio69,bigwheel15
    TRADED: RnK1026,wasted ink
    Vermithrax's Avatar
    Vermithrax is offline CarAudio.com Elite
    Sep 2007
    House
    649
    IIRC, the precision port tubing is 1/16" thick. That makes the OD 4-1/8. Sch 40 PVC is 4-1/2 I think. You can get closer by using SDR35 sewer application PVC. The pipe has a thinner wall, still thicker than the P-P's. You could wrap the P-P tube with tape or thin deadener to take up the slack and create a tight fit.
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Quote Originally Posted by Vermithrax View Post
    Ok cool I am going to check it out.
    TY, Jeff
    gotparts90's Avatar
    gotparts90 is offline CarAudio.com Elite
    Jan 2008
    chicago
    1,676
    yeah try that sewer pipe I know there is a pvc that will fit go to a supply house with it and look at some. if you are in the northwest suburbs go to wagner and sons in wheeling or it might be prospect heights
    O my liver!!!!!!!!!!!!!!!!!!!
  9. #9
    davescomptips's Avatar
    davescomptips is offline Junior Member
    Feb 2009
    Indiana
    18
    How about cutting each end at a 45 degree angle using a miter box. CA and/or hot glue the pcs together. Use caulk to seal the joint and, if possible, sand the joint lightly on the inside.
  10. #10
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    I found the sewer pipe pvc and that is going to work good. It adds 6.5" of port length also. I need 20.23 so this actually works out great.
  11. #11
    gotparts90's Avatar
    Jan 2008
    chicago
    1,676
    the 90 ads more that actually length to the tuning I forget how much I hope someone can find the formula that tells the restriction to it and how much to cut off because of it. It is similar to like when you make a labyrinth slot port.
  12. #12
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Yea I def hope someone chimes in if that is the case...
  13. #13
    gotparts90's Avatar
    Jan 2008
    chicago
    1,676
    with one 90 it is not gunna be much difference but a little. try to see if you can find and fit long sweep fittings. less restriction and acts more like a straight piece.
  14. #14
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Here is the 90 and this is how I was told to measure it. That is where I got the 6.5 to add to the port length.
