Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: 4" aero port box designs
    gqjeff's Avatar
    gqjeff is offline Waz up????
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Does anybody have a link or some designs for 4" aero ported boxes at say 1.75 and 2 cu using 1 and or 2 4" aero ports. Its going to be for a DC level 4 10" sub. I am thinking 32,33 or 34 Hz.. Was getting prices but I think I want to take on the challenge.. If it does not work out I will buy one from one of the builders.
    TIA, Jeff
    HlorridiXplorer's Avatar
    HlorridiXplorer is offline Loud Rider
    Sep 2008
    Louisville Ky
    29
    94
    Re: 4" aero port box designs
    go to ww.psp-inc.com and go to the port calculator on the left hand side and fill in the boxes and just mess around with it to see what will work in your car and still satisfy your needs.
    2001 Ford Explorer Sport
    H/U: Alpine IVA-D105, w/ SBS-05DC
    Front comp: Type R's
    Rear comp: Type R's
    Comp Amp: ZX650.4
    Subs: 18" Nightshade
    Amps: SAZ-3500D
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    yes went there but it does not show me dimensions for the box at all. Trying to find the proper dim for the box and also find out discplacement for the sub and 1 or 2 4" aero ports. Also should I have the ports facing rear also like the woofer or coming out the side?
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    one of the big issues with aeroports in that small of a box is that unless you side port them...you almost always have to put a 90 in there to bend the port. I'm building one right now 2.5 net with 2 4" ports.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    I was just told about using 90 degree elbow so that frees up some space.. They do not have to face rear like the sub just thought that would look cool.. Also any adj over 1 to 2 ports?
    bonesninja's Avatar
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    Quote Originally Posted by gqjeff View Post
    yes when going from 1 to 2 ports, in order to keep the same tuning the ports get quite a bit longer.
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Volume of Box in Cubic Feet: 2
    Tuning frequency 32
    Port diameter 4
    Number of Ports 1
    Straight Length Port required 13.61
    Flare Length Port required 14.61
    Going flared so if I could get some dimensions that would be cool. Can you also take into displacement also if you send me dimensions.
    Sep 2008
    Louisville Ky
    29
    94
    measure the available space you have in your car then figure the shortest ports you can run with tuning you want which will probably be the single 4" aero. then figure out the measurements for the box. what car is this going in? ports back is usely loudest and subs forward but it depends on the car.
    Rear comp: Type R's
    Comp Amp: ZX650.4
    Amps: SAZ-3500D
  9. #9
    Lakota's Avatar
    Lakota is offline Doesn't Know $hit
    Feb 2005
    Louisville, KY
    30
    6,222
    Shouldn't be hard to fit, at all.
    Ben Hemp
    1992 GMC Sonoma Ext Cab NEW BUILD
    2008 MECA S1 KY State Champion, 151.0 dB
    2008 MECA S1 WorldChampion, 151.8 dB
    2010 MECA scores: 150.9 dB S2, 151.6 dB S3
    Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
  10. #10
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Going in the jetta in my avatar.. trunk is 40*40 and the opening is 17"*36 but I am sure I can drop the rear seats and get it in that way easier. So port facing the cab coming out of the rear will be the best?
  11. #11
    KHARPS's Avatar
    KHARPS is offline CarAudio.com Veteran
    Jul 2008
    IL
    31
    3,332
    I still think you should do sub/port back
    REFERENCES
    cam5860, Godsmack, dropkick13, ls2poweredgoat, bunkerking09, ProjectPechkin, GavinVoy, kmanian, magnum21, natetate, gqjeff, mustangowner, ssackett, hazardous0388, Rusty...WCA, ohsosmooth, grassroots, Leister, Scott S, Pyro_by_Nature, teamsolo, jblcamry, pickup1, got_focus?, fasfocus00, Zellner, Goindef154, Darknight, orangelss, Thorshammer1, BigSix
  12. #12
    bonesninja's Avatar
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    here's a sneak peak of an aeroport box that i'm working on right now. not quite finished with the ports yet
  13. #13
    Lakota's Avatar
    Feb 2005
    Louisville, KY
    30
    6,222
    Try sub forwar/port side or sub forward/port forward. If that doesn't work, then you can always rotate the box
    Ben Hemp
  14. #14
    gqjeff's Avatar
    Jan 2009
    IL
    951
    1 Post(s)
    2 Post(s)
    Quote Originally Posted by bonesninja View Post
    Seeing the pic helps.. You take into account the length of the 90 degree also correct? If so how do you measure the inside or outside or center length of the elbow?
  15. #15
    bonesninja's Avatar
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    i just took a string and laid it right down the center of the bend and then measured the string.
