Results 1 to 6 of 6
Reload Thread: fiberglass box question
    Doberdad's Avatar
    Doberdad is offline CarAudio.com Elite
    Jan 2003
    gb wi
    32
    650
    i just have to put the fleece on my box tommorow. do i just resin the fleece and put the mat inside? i figure it will b easier to sand that than the mat on the outside, but wont i sand right thru that. this is my first box, so i just need to know if i should put the mat on the inside or outside
    2006 VW Jetta 2.5L 6Speed Manual. INEEDSOMEBASSasap
    system:
    In Progress(new vehicle)
    WTB
    jl w3 or jl w6 series sub
    Doberdad's Avatar
    Jan 2003
    gb wi
    32
    650
    Re: fiberglass box question
    ??? help me
    system:
    WTB
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    I was told to put the matt on the inside of the box, so it's a lot less sanding later on ...
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    Doberdad's Avatar
    Jan 2003
    gb wi
    32
    650
    that is what i thought, will i need as many layers on the inside as i did the base of the box(7layers)
    system:
    WTB
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    Wind up with 1/2" or thicker for the front of the enclosure ... so a bunch of layers anyway.
    - Stve
    Moderator
    2007 Chrysler 300C
    ASDF12345's Avatar
    ASDF12345 is offline Senior VIP Member
    Nov 2002
    us
    260
    put the mat on the outside. idealy it would be better to put it on the inside. but trust me, it isnt worth the hassle. trieng to get an even layer of mat on the inside of a box is incredibly hard and time consuming, your resin will dry before you finish one layer. yes it will make sanding easier. but if youve ever sanding a fiberG box before an extra few hours is nothing when compared to the weeks you will spend on it. yes i said weeks. im sure you have read that sanding is a ***** and its very time consuming but words dont do the process justice. im a perfectionist so maybe its easier for other people but when i like to see my box shine and be flawless when its all painted up.especially when people are spending the loot to get it professionally painted. the project car im working on right now will be painted to match the car then airbushed to look like a bionic machine. the sanding is the most important part of the project. lay the mat on the outside of the fleece. after you build up the mat to the thinkness you want throw down one or two layers of woven mat. that will help you get it smoother. then start using bondo and sanding. then repeat. after you get it nice, use a lightweight body filler and throw some paint thinner in themix to make it lighter. spread that around and sand it and you should be mint.
  1. check out my fiberglass box *PIC*
    By subboxmaker in forum Enclosure Design & Construction Help
    Last Post: 01-31-2004, 02:14 AM
  2. Amp ground question
    By Jbarbier in forum Amplifiers
    Last Post: 08-22-2003, 09:22 PM
  3. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 12:08 PM
  4. Another Fiberglass Question
    By BDIDDY in forum Enclosure Design & Construction Help
    Last Post: 08-04-2003, 12:08 AM
  5. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
