Results 1 to 9 of 9
Reload Thread: Mounting Hole Size for 8" Sub?
    Zsx5o1's Avatar
    Zsx5o1 is offline Member
    Jun 2008
    CT
    30
    Hi Guys. I was planning to build my box today but forget to gather the mounting hole size from my audio shop which is now closed
    The sub I'm using is an 8" Memphis M-Class (15-MCP9S4). The mounting depth is 4"
    Are all 8" subwoofer mounting hole sizes the same? Can I get as close as possible to the size so I can continue my project? Thanks in advance!
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Re: Mounting Hole Size for 8" Sub?
    It's prolly like 7-7.25.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    Ellsworthz's Avatar
    Ellsworthz is offline 98' firebird, sleeper ftw
    Aug 2008
    Decatur, Indiana
    25
    1,830
    1 Post(s)
    do 7.25
    Zsx5o1's Avatar
    Jun 2008
    CT
    30
    Thanks! If no one has a precise answer I will cut for 7" and sand the difference when the sub arrives
    W8 a minute's Avatar
    W8 a minute is offline CarAudio.com Elite
    Sep 2006
    St. Peters. MO
    956
    I say 9 inches. It should drop right in.
    Refs: Kmanian, Mj-TC, mennitti, iceteebone
    Kil4Thril's Avatar
    Kil4Thril is offline Member
    Jan 2008
    home
    121
    Usually 7 1/8" covers most subs except the ones on 12-spoke cast baskets. Those baskets annoy me
    2008 Sport Trac
    Kenwood DDX7019
    Kenwood KAC X4R & X1R
    Alpine Type X 177REF
    Sundown Audio SD1v2 (x2)
    Alex JB's Avatar
    Alex JB is offline Senior VIP Member
    Oct 2008
    Chicago IL
    260
    12 Post(s)
    what did you go with?
    my E8's went in easy with 7.25" dia hole.
    You could have gome with the other fellas 9" suggestion.... mounted your sub cone facing out to a plate with a 7" hole (check for soft part clearance) and mount the plate to the box, then you get a some level of protection.
    JL 6.5's in the front doors
    AP1040 bridged driving them.
    2 Sundown E8's in 1.1cu ft tuned to 30Hz.
    700rms @ 2Ohm Cadence... let's see what the the E8's can take
    q-ball's Avatar
    q-ball is offline SPECIAL!
    Jul 2008
    johnstown, PA
    336
    my ed 8's are 7 1/8"
    Ride: 06' Nissan Frontier Nismo
    System:H/U-Kenwood excelon kdc-x792
    Mids-Memphis MC-6.5" Comp set F/R
    Amps-Memphis MC4.75
    Memphis MC1.500
    Subs-Kicker L7 8" x2
    Bought From: dantedibrosel, B-Rock
    Traded With: louisianne_CRX, Worstenemy453
    EBAY:Q-ball814
  9. #9
    brokeitagain's Avatar
    brokeitagain is offline auto body tech:)
    Jan 2007
    MO
    38
    326
    the m class cutout is 7 1/16'' . 7 1/4 is too big and the screws break out of the wood easily
