Results 1 to 9 of 9
Reload Thread: please help step by step of building a box for 15A
    mdd99's Avatar
    mdd99 is offline Member
    Jun 2003
    Los Angeles, CA
    28
    132
    can you tell the step: what i need to buy, where to buy them...anything in the process of building a box... and if i dont' have the hole cutter thing where can i go to get a hole cut out..
    thank for helping..
    kingpin_jeffie's Avatar
    kingpin_jeffie is offline i need a vacation...
    Mar 2002
    Erie, PA
    1,259
    4'x8' sheet 3/4" mdf
    # 8 1 5/8" wood screws
    Wood Glue
    Silicone caulking
    Jig Saw
    Drill
    All available at local hardware store.
    Eclipse 8445|Alpine Type X 137r|Diamond D5 300.2/1200.1|ID 10v.3|
    Refs: KARLEON, sephiroth619, SiX, Showrides, angrytrucker78, davidfre21, Relax, Slammed
    He who laughs last is usually the slowest...
    HUDI's Avatar
    HUDI is offline Senior VIP Member
    Jan 2003
    aus
    39
    273
    36
    u might wanna work out ur sizes 1st &how much mdf u need
    6 x CROSSFIRE BMF XT15 33cub box tunned to 56
    6 X CROSSFIRE VR 2000D
    LANZAR DC 8INCH SUBS in the doors
    1 X CROSSFIRE VR 1000D
    CROSSFIRE P seires 6inch mid in doors
    CROSSFIRE Pseires 4inch mid &tweet in stock postion
    2 x CROSSFIRE VR402
    NAKAMICHI 302 3way crossover controling front stage
    6 x OPTIMA batterys
    18 x 2volt deepcycle batterys
    Mar 2002
    Erie, PA
    1,259
    Well if its one of the boxes off eD's site then a 4x8 sheet will give you enough to build the box and have enough left over to build an amp rack or two.
    mdd99's Avatar
    Jun 2003
    Los Angeles, CA
    28
    132
    Re: please help step by step of building a box for 15A
    how many
    is that 1 and 5/8 inches you mean
    namster44's Avatar
    namster44 is offline Great White North
    May 2002
    Canada
    646
    yes, you will need about 100000, or more....
    actually, 50 will be more than enough.
    This years line up.....
    *eD, Tsunami, CDT, Alpine, EFX wiring/block/fuses*
    mdd99's Avatar
    Jun 2003
    Los Angeles, CA
    28
    132
    and where do you put the screw ..i dont' see anyone use screw for their box
    Jun 2003
    Thief River Falls, MN
    43
    128
    http://www.dbfanatics.com/forum/phot....asp?sqldtl=16
    while i have been told i go overboard with them....that is just how i do it.
    look in the sub box category.
    Monty
    excelon|PPI|Tsunami|eD|Diamond Audio|peal and seel|
    USACI b-stock 601+ best of 153.3 aiming for 155
    dbdrag street A best of 143.5 on new sensor
  9. #9
    Mar 2002
    Erie, PA
    1,259
    musthavemuzk your quite mad you know.
    but then again your attention to detail is probably why your hitting in the 150's with your A and I'm not.
