Results 1 to 3 of 3
Reload Thread: Are the L-7/L-5 dual vented boxes anygood by Subzone?
    Indybassman's Avatar
    Indybassman is offline Senior VIP Member
    Aug 2003
    Covington,Ky./Cincinnati,Ohio
    49
    209
    Icon32 Are the L-7/L-5 dual vented boxes anygood by Subzone?
    I was considering the dual 12" one.Since forth I haven't any box building experience.What,so ever!
    My Bass,Must Be Very PowerfuL!!
    NOCRYIN-NOW!!
    AMD's Avatar
    AMD
    AMD is offline Member
    Aug 2003
    independence, mo
    76
    I used one when i was building an enclosure for my 2 l712. It is not that bad of a box, it is a little small at only 1.93 cu ft per sub after discplacment, but it sounds pretty decent. It will get pretty loud, and the design and material is decent. I would say if you are getting it cheap then go for it. but if not then spend the 30-50 dollars and build your own, because the l7 really wake up in about 3 cuft tuned at about 30 or so. but i would say you would be happy with the subzone.
    good luck
    Aug 2003
    49
    209
    Re: Are the L-7/L-5 dual vented boxes anygood by Subzone?
    Thanks for the replys guys!
    NOCRYIN-NOW!!
