Results 1 to 5 of 5
Reload Thread: Elemental 15A box Question
    BumpinDoug's Avatar
    BumpinDoug is offline 15A's B!TCH
    Jun 2003
    Atlanta
    33
    523
    Okay, Im getting two 15's and I want to port them, the problem is I only have a 35" wide trunk space to work with. Assuming it has a 3" port, and 3/4 MDF is used for the slot port and the walls of the box, that would leave 14.5" left for each sub. However, the radius of the mounting hole only needs to be 14" each. So therefore that would leave a 1/4" between the mouting hole and the wall on the inside on either side of the hole. Also, there would only be a half inch between the end of the actual sub and the end of the box. Is a quater inch enough room to mount these subs, and is a half inch enough room between the sub and the end of the box? Psyically, it would fit, but that could mean drilling into the MDF used for the side of the box and the port sideways...so could that damage or make the board split down the road?
    I just want to know if this will work and sound good. The total dimensions of the box would be 35 wide X 17.5 tall x 17.5 deep....about 4.3 cubes with displacement, tuned to 32HZ...
    Everyone please put in any input you have.
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Re: Elemental 15A box Question
    4.3 after all displacements should be fine...
    Just when mounting the sub be careful that you don't split the wood when screwing into it, considering you have such little room with the walls there...
    BumpinDoug's Avatar
    Jun 2003
    Atlanta
    33
    523
    Anyone else know anything about mounting it so close to the side of the box?
    namster44's Avatar
    namster44 is offline Great White North
    May 2002
    Canada
    646
    I dunno about that man, that's real close to each other, I know the holes are going to fit the sub, but with the surround and stuff, it will be iffy.
    This years line up.....
    *eD, Tsunami, CDT, Alpine, EFX wiring/block/fuses*
    BumpinDoug's Avatar
    Jun 2003
    Atlanta
    33
    523
    The subs wont be next to each other cause the port will be in the middle, if viewed from above the box with the top off it would go like this...
    3/4" of MDf, then 14.5" of space (14" of which will be used on the front baffle to mount the sub), then 3/4" MDF for the port, then a 3" port, then 3/4" MDF for the other wall of the port, then 14.5" of space for the other sub, and finally 3/4" of MDF for the other wall. That all wokrs out to 35" which is all I have to work with. This leaves .25" on either side of the sub on the interior of the box, and .5" on either side of both subs viewed from the outside. Anyone else know if this would work or not? I know ED subs perform well in small enclosures....and itd still be about 4.3 cubes, width is the problem. Would it be better to use 1" MDF on the front baffle so that there would be a less chance of the wood splitting? Cuase with the two subs cutout and the hole for the port, theres really not gonna be all that much wood on the front baffle to begin with, so would it be wiser to go with 1"? And is this box even gonna work?
  1. Amp ground question
    By Jbarbier in forum Amplifiers
    Last Post: 08-22-2003, 09:22 PM
  2. sub and ohms question
    By jayrebb in forum Wiring, Electrical and Installation Help
    Last Post: 08-20-2003, 11:57 AM
  3. new and a question
    By Sqfreak in forum General Discussion
    Last Post: 08-16-2003, 05:42 PM
  4. Amp for 2 Elemental Design O Series
    By Tanto420 in forum Amplifiers
    Last Post: 07-13-2003, 09:37 PM
