Results 1 to 13 of 13
Reload Thread: 3 DD 1515s Chevy Tahoe NEED PLANS!!!$$$
    DavaFlava's Avatar
    DavaFlava is offline Member
    May 2008
    Smyrna, Tennessee
    62
    Max: 27d 49w 16.5h
    Used only for rap music, so I need it lowww.
    Subs up, port back sounds great in Tahoes.
    I need plan ASAP. Need a cut sheet and all. I got money in the bank.
    holla!
    4 T3 Audio TS 12s
    2 Kole Audio 4000Ds (about 1200rms each)
    1990 CRX
    Hairtrick.
    Refs: Buck, Bobtista, BlkCamSS01
    FAIL: http://img.photobucket.com/albums/v6...craigslist.jpg
    dbeez's Avatar
    dbeez is online now CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Re: 3 DD 1515s Chevy Tahoe NEED PLANS!!!$$$
    Mike465 hit him up..
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
    DavaFlava's Avatar
    May 2008
    Smyrna, Tennessee
    62
    anyone?
    4 T3 Audio TS 12s
    1990 CRX
    Hairtrick.
    DBDRAGGUY's Avatar
    DBDRAGGUY is offline CarAudio.com Veteran
    Dec 2007
    BURLINGTON,KY
    2,227
    No disrespect , but this is something that you should be able to design yourself.
    Fairly simple ,even more so if you use aero ports.
    http://feedback.ebay.com/ws/eBayISAP...me=STRK:ME:UFS
    Dealt with:Worlddre,KeifersRacing,Crxbmpn,76Nova,Foote,F astimes,Bad @ss Chevy,themommyvan,22mountaineer,Tacosys.Fiercetimb o17,RAB, djman37,dtbrown,Louisana CRX,Tricked,Tinted,dcmcki,99grandprixGT,FLOSSINON2 4S
    BAD EXPERIENCE WITH bigredhybrid AKA JIM BECKER
    91 Honda Crx. Street C 155.7 db
    Usaci Stock 1800-3000 158.0 db
    Usaci Stock 601-1800 154.9 db
    Usaci Super Port Wars 174.1 db
    Real Old School >http://www.youtube.com/watch?v=38_MwcGDNhQ
    DavaFlava's Avatar
    May 2008
    Smyrna, Tennessee
    62
    well if you want to make a quick $15 you can do it for me
    thanks
    4 T3 Audio TS 12s
    1990 CRX
    Hairtrick.
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    use RE's box calculator its free
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
    DBDRAGGUY's Avatar
    Dec 2007
    BURLINGTON,KY
    2,227
    http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
    Like La CRX said this is all you need and it is free.
    Dutchie.'s Avatar
    Dutchie. is offline Range Rover Classic
    Dec 2008
    VA
    212
    Contact fallen at roe.
    Bought From:
    jrgreene1968
    Louisiana_CRX
  9. #9
    DavaFlava's Avatar
    May 2008
    Smyrna, Tennessee
    62
    i need this done. thanks.
    4 T3 Audio TS 12s
    1990 CRX
    Hairtrick.
  10. #10
    DavaFlava's Avatar
    May 2008
    Smyrna, Tennessee
    62
    Can anyone help? I'd like to star building tonight
    Thanks forum
    4 T3 Audio TS 12s
    1990 CRX
    Hairtrick.
  11. #11
    Canaan's Avatar
    Canaan is offline Beatin' the block down
    Mar 2006
    Monroe, Louisiana
    1,432
    3 Post(s)
    You are a little low of space for 3 DD1515's.
    I have a design already made up for 3 DD1515's in an SUV, but is is larger than 27". I think it is 32" and needs a ~4-5" space between the port and back hatch.
    I'll slap you something together for your vehicle though.
    Gimme a min.
    Canaan White
    -'04 Avalanche, Eclipse 7200MkII, DD C4a, DD AT28 and AW6.5 (German comps) active,
    -2 DD3515E 6th order, 2 DD M2a @ 1.5ohm, 150+ @ 38hz
    Team South
    Desiard St. Pawn and Car Audio
    DD, Arc, Sundown, HAT and dB Drive Dealer
  12. #12
    Canaan's Avatar
    Mar 2006
    Monroe, Louisiana
    1,432
    3 Post(s)
    Build to your original dimensions....49,16.5,27.
    Use Three 6" ports 14" long.
    Subs up, ports back, brace the baffle between the subs w/ two ~4 x 25.5 braces front to back on the box.
    That will be right at 2.9cuft per sub. That is pretty small, so I would actually recommend doing the same box, but just use 2 15's.
    Canaan White
    Team South
  13. #13
    DavaFlava's Avatar
    May 2008
    Smyrna, Tennessee
    62
    I have new measurements!
    34d 26w 20h
    20" is window line but I can go another 6" higher.
    This is not for competitions just daily.
    Thanks guys
    4 T3 Audio TS 12s
    1990 CRX
    Hairtrick.
