Results 1 to 5 of 5
Reload Thread: 1/4" MDF for ports?
    SPLThunder's Avatar
    SPLThunder is offline CarAudio.com Elite
    Sep 2002
    508
    Icon32 1/4" MDF for ports?
    In order to make a large box in my trunk i need to make the slot ports out of something that is 1/4" thick. I think this is ok because they are just ports but i dont know what would be the best material to use becasue 1/4" isnt very easy to screw into. Is this ok and should i use mdf. Would glue and brad nails work better?
    They are completly external slot ports.
    Is 84^2 inches good for port surface area. The port velocity would be low enough but for SPL applications do i need to take anything else into account.
    defiance's Avatar
    defiance is offline Member
    Aug 2003
    Little Rock, AR
    41
    129
    Re: 1/4" MDF for ports?
    I don't know if ports have any real stress outside of their construction, so I can't really give much advice on that aspect... However, if you do end up using it, I wouldn't screw it in or screw it together, I'd construction adhesive. After my recent experience with the stuff (posted pics earlier; I had to completely destroy the front panel from my box to get it apart!), I'm a believer
    accord18's Avatar
    accord18 is offline Junior Member
    Aug 2003
    greenfield, IN
    31
    26
    if they are external see why it wouldnt work but defenitely dont screw into it use liquid nails
    blitz25's Avatar
    blitz25 is offline preacher man
    Sep 2002
    round rock texas
    43
    128
    id believe the port would be carrying the pressure from inside to the out and would flex but i could be wrong.
    alpine cda-7893 h/u 4volt preout
    boston5x7s in front
    boston 6x9 in rear
    mtx4202
    sony [email protected]
    three kicker compvr10s
    149.7db
    in ford ranger single cab pix are in go see
    system changing have 4 solo s10L5 putting in a down firing configuration amp decision to come Its funny how a family can be torn apart by the simple things in life. such as a pack of wild dogs for instance.
    SPLThunder's Avatar
    Sep 2002
    508
    the top and bottom of the ports will be 3/4" and the sides of 1/4" will be screwed into the top and bottom. It will help with some. The ports will also be pretty snug up against the side of the trunk. If they arent tight enough i could brace them with something else very small.
    edit: 300 POSTS.......BONG
