Results 1 to 3 of 3
Reload Thread: 4 15' se's box suggestions?
    Mar 2008
    Clarksburg WV
    104
    I built a box a while back for 4 15" PB 2xls and but now im thinking about porting it and putting 4 re se's in it, the only problem is that the box flexes a good bit since there is no bracing in the center. will i be able to push these subs to their full potential with this box ? Oh and i dont know the volume of the box yet but i am going to use packing peanuts to get an idea.
    http://i357.photobucket.com/albums/oo20/autosportsunltd/the%20d/newdurango044[/URL]
    i
    Cameron_B's Avatar
    Cameron_B is offline Single Cab Loud
    Jun 2008
    NC
    1,403
    Re: 4 15' se's box suggestions?
    the general consensus for most around here is
    1.2 per 10 at 32hz
    2.0 per 12 at 32hz
    4.0 per 15 at 32hz
    Past scores-
    144.1
    2x re SE + aq2200 2.8 SEALED in 1995 Camaro
    141.0
    Custom PSI 10" 5.25 depth ported aq2200 1994 ford ranger
    139.9
    RE SR 10" on ED 9.2x 1994 ford ranger ported
    luv2shrOOm's Avatar
    luv2shrOOm is offline In my TONKA !!!
    Feb 2007
    452
    15 Post(s)
    i'm doin a box soon for 4 15" se's. it's gonna be 15^3 @ 30Hz with (4) 6" aeroports, subs up and ports back along the bottom.
    Refs:
    ~Finalwolf
    ~Wrathchild281
    ~Cleansoundz
    ~Wkdbkid
    ~SubNit
    ~Leister
    ~Adas
    ~SELFMADE
    ~Goindef154
    ~ProjectPechkin
