Results 1 to 8 of 8
Reload Thread: Help with slot port turn
    qtipextra's Avatar
    qtipextra is offline The Original
    Jun 2004
    Idaho Falls, Idaho
    24
    5,006
    I need to have a 25" long port. This port the way it is drawn out right now is too long. However, when you measure middle to middle, in order to get 25", (without figuring in the angle board in the corner) it ends up 1" short of the port width.
    Also, how do you figure in the angle corner piece?
    "Big D"
    2003 Dodge Durango
    Pioneer DEH-P780MP - Pioneer USB Adapter - Toshiba 2.5" 60gb Hard Drive
    6.5" Pioneer REV Components - PG Xenon X100.2 - PG TLD66 Line Driver
    2 12" RE SE's - 4.5 Cubic feet @33 hz - RE 12.1 - KnuKonceptz 1/0 AWG Wire
    Refs: Moe Lester, Team PSI, Thisisausername, CaliforniabOY5, MikeyB, SPL140.2, hoxie08, ECS23
    My Ebay user name is qtipextra01os.
    mobeious's Avatar
    mobeious is offline what does 0hz feel like?
    May 2004
    Bartow, FL
    4,838
    26
    Re: Help with slot port turn
    u need to angle the actual port board
    just shorten that up a lil bit and it will be fine
    Alpine CDA-9833
    (2)sets Cresendo ccx65
    Box Engineer for
    qtipextra's Avatar
    Jun 2004
    Idaho Falls, Idaho
    24
    5,006
    Quote Originally Posted by mobeious View Post
    Could you elaborate a little bit more? What do I need to angle? What do I need to shorten up?
    Thanks!
    "Big D"
    2003 Dodge Durango
    BrianChia's Avatar
    BrianChia is offline CarAudio.com Elite
    May 2007
    Knoxville/Nashville TN
    1,292
    The effective slot port length is found by intersecting it with 45 degree angle with enclosure wall. This is how you measure it, right down the middle:
    qtipextra's Avatar
    Jun 2004
    Idaho Falls, Idaho
    24
    5,006
    Quote Originally Posted by BrianChia View Post
    So I would basically measure it like this (the center line)?:
    This is not an exact sketch, but this is just to give me an idea of what I need to do to get exactly 25".
    "Big D"
    2003 Dodge Durango
    qtipextra's Avatar
    Jun 2004
    Idaho Falls, Idaho
    24
    5,006
    Bump
    "Big D"
    2003 Dodge Durango
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    30
    12,810
    You need to factor in 3.5" for port end correction. other than that yes...
    qtipextra's Avatar
    Jun 2004
    Idaho Falls, Idaho
    24
    5,006
    Quote Originally Posted by tRiGgEr View Post
    Just to make sure, I add the 3.5" onto the overall length for end correction, right?
    "Big D"
    2003 Dodge Durango
