Results 1 to 4 of 4
Reload Thread: ?'s About vent dimensions?
    MXJMR's Avatar
    MXJMR is offline Senior VIP Member
    May 2003
    Naptown, IN, US of A
    212
    I am building a box, for two 15"s. The vent length is longer than my box so i am going to have a 90 degree turn in it but i think it may go over to far. Will it affect anything if the port goes more than halfway acroos the box?
    The dimensions for both sides are the same. Here are the dimenions of one side, w21" x h18" x d18". The vent dimensions are w2" x h16.5" x L29.75.
    Do u think having the vent turn and go about 15" across the inside of the box will make a difference in sound? Any suggestions would be helpful.
    ShaunMac's Avatar
    ShaunMac is offline Thank You Come Again!
    Feb 2003
    GEORGIA
    585
    Having a bend in the port won't affect the sound of the box.
    As long as the port is the correct size. I've heard many boxes with long ports that had to have multiple 90 degree bends. They sounded just fine.
    You'll be alright.
    Pioneer 8600 - Profile Amp-Infinity Speakers - L7 Subwoofer
    MXJMR's Avatar
    May 2003
    212
    Even if it goes almost all the way across the box. I guess it should work i just wanted to make sure.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    Should be just fine.
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  1. Port dimensions
    By Biohazard in forum Enclosure Design & Construction Help
    Last Post: 08-13-2003, 09:41 AM
  2. dimensions and type???
    By WD2 in forum Enclosure Design & Construction Help
    Last Post: 08-08-2003, 10:52 PM
  3. sub box dimensions for silverado
    By morganator88 in forum Enclosure Design & Construction Help
    Last Post: 07-28-2003, 03:24 AM
  4. Slot port dimensions
    By debutis in forum Enclosure Design & Construction Help
    Last Post: 07-14-2003, 12:28 PM
