Results 1 to 7 of 7
Reload Thread: FAN in AMP rack
    EVOECLIPSE's Avatar
    EVOECLIPSE is offline Senior VIP Member
    Jun 2002
    New Paris, OH
    29
    186
    FAN in AMP rack
    i plan to place my amp under the sub box in a chamber... i am running the amp at 4 ohms... there will be plenty of places for air to get in... but i was wondering if i should put a small fan in there as well... i am running at 4 ohms so the amp will not be working as hard if i were runnin at 2 ohms... does ya'll think a fan would be necessary?????
    03 S-10 xtreme
    HEAD UNIT - Kenwood Excelon KDC-X869
    4X6'S - Kenwood Excelon KFC-X468c
    6.5's - Kenwood Excelon KFC-X168
    SUB AMP - JBL BP1200.1
    SUB - Kicker Solo Baric S10L7D2
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    It can't hurt anything. The cooler the better.
    2006 Jeep Liberty
    Adire Audio, Cadence, Clarion, MB Quart
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    MXJMR's Avatar
    MXJMR is offline Senior VIP Member
    May 2003
    Naptown, IN, US of A
    212
    Amen
    I 2nd that
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    20,875
    36 Post(s)
    indeed....can usually find a cheap 12v fan at radio shack....they work quite well
    MXJMR's Avatar
    May 2003
    212
    Ebay all the way baby! You can find some with leds for like 2/$.99
    EVOECLIPSE's Avatar
    Jun 2002
    New Paris, OH
    29
    186
    how does a fan connect???? i have never installed a fan before any suggestions????
    03 S-10 xtreme
    Trixter's Avatar
    Apr 2002
    Kenosha, WI
    35
    2,608
    29
    If your just using a small, single fan you can get away with hooking it up to your remote line. I have had three hooked up to my ignition wire with out any problems. Some people may suggest using a relay but I don't and have not had any problems. Simply power up the positive and find a ground for the negative.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  1. Amp Rack
    By 67impala in forum Enclosure Design & Construction Help
    Last Post: 07-28-2003, 09:57 AM
  2. 2000 watts at 1 ohm
    By bri487 in forum Amplifiers
    Last Post: 07-23-2003, 04:44 PM
