Results 1 to 4 of 4
Reload Thread: 18" FI Q Enclosure
    farmerehsan's Avatar
    farmerehsan is offline 144.6 db
    Nov 2008
    Tampa
    2,449
    18" FI Q Enclosure
    Hi i need some help to make a box, i kno nothing about it.
    I have a nissan xterra 2004 dimenions 3x2x 1.5.
    i would liek to use the smallest box possible according to the knowledgable on here.......
    Q18
    DUAL 1 | DUAL 2
    Fs: 24.5 Hz | 23.8 Hz
    Re: 0.7 Ohms/coil | 1.4 Ohms/coil
    Qms: 5.66 | 5.73
    Qes: .64 | .63
    Qts: .58 | .57
    Mms: 322g | 342g
    Cms: 0.13mm/N | 0.13mm/N
    Sd: 1210cm^2 | 1210cm^2
    Vas: 268 l | 268 l
    Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
    Bl: 10.4 N/A | 15.1 N/A
    Xmax: 27mm
    Rms: 1000W
    Sealed box: 4-8 cuft
    Ported box: 6-10 cuft @ 28Hz
    Sub OD: 18.500
    Cut ID: 16.750
    Mounting depth: 10.000
    Displacement: 0.24cuft
    can i do a 6 cuft box? a 2 x 2 x1.5?
    any help thanks
    ARSkemp's Avatar
    ARSkemp is offline FI-AQ-PA-AB-Profile-MB-RD
    Mar 2007
    Salas/Chico, CA
    603
    Re: 18" FI Q Enclosure
    First, if the box is 2' x 2' x 1.5', then its not going to be 6 ft^3. Displacement of wood/sub will make it smaller, especially if you want it ported (you have to then take into account the displacement of the port as well).
    edit:
    Is 3x2x1.5 your max dimensions? Every inch helps, and if those are your dimensions you will probably be able to barely fit a 6 ft^3 (internal) ported box into your trunk.
    Vehicle - 03 Ford Escape XLT
    Head Unit - Eclipse AVN2210P w/Kicker KQ30
    Frontstage - PG RSD 6.5 Comps
    Front Amp Some Profile Amp (forgot model #)
    Subs - old 4 12" AQ SDC2.5s new - 2 10" RD Alphas
    Sub Amp AB500.1 @ .5 ohm
    Box 8ft^3 tuned to 38hz (built by Rashadd) new - 2.5ft^3 tuned to 36hz
    Electrical - Kinetik 2400, 2 Powermaster D3100's
    150.3 Legal @ 45hz (sealed up on dash w/TL) new - unknown
    Build Log: Click Here <---Vids in Post #48
    Refs: Nate2587, morgans432, bbrownderville, Skip01, Incriminator, Rashaddd, vondocha, 528hz, dron178
    IDSkoT's Avatar
    IDSkoT is offline Resonating Reticular
    Jan 2008
    Miami, Florida
    6,274
    With those measurements, using 3/4" MDF (which is recommended), the max gross space you can get is 4.83... which is barely enough for sealed... and when you factor in the sub's displacement, you're left with a measly 4.59 cuFt.
    I say either get more room, or get the 12, or 15.
    Now designing / building boxes.
    (Only building sealed and aero port boxes.)
    PM me.
    Feedback Thread
    Refs: MSW Danny, atsaubrey (great seller), ampjunkielikeme, wgsj_fortvalley, tEh koRnDog, bad @SS chevy, Nismos14 (who is the man. )
    Rashaddd's Avatar
    Rashaddd is offline Terrrrrist
    May 2008
    Sacramento
    5,095
    Quote Originally Posted by ARSkemp View Post
    edit:
    @ your avatar
    send me fullsize pics...now!
    Refs: themommyvan, CharlieAnderson, bassknocker23, bigbirney420, wu501, _JaY_, lrc131, R/T Pimp, NeverEnuffBass, d-REW, slapmaster, headbussaboi, edzy, adio, 1ndatrunk, jfink, k_schutte, bigredhybrid, ARSkemp, s-saudio, pimpdaddyq, AudioFreak, scarolinablazin, ssackett, kylebechtold, craigzter, etc..................
