Results 1 to 5 of 5
Reload Thread: Slot or Square Ports
    havoc06's Avatar
    havoc06 is offline The Juggernaut
    Jun 2003
    VA
    36
    461
    I posted this thread before but didnt really get an answer, so ill try again. I always figured that a slot and square port were the same thing, but on a recent post here i read that if you use walls of your enclosure to share also as walls of your port, then it is a slot, not square port, and you have to do some extra calculation to make sure its tuned correctly.....does anybody know this to be true or not, or can give me some info on it?
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    35
    8,044
    Quote Originally Posted by havoc06
    yes that is the dif. if you think about it a square port looks just like one as does a slot port only dif. being a square isn't the entire side of a box. you can use a wall of your box and not have it be a slot port though if you don't use the whole thing i think not sure though.
    adam
    2006 Bright Island Blue 6s: stock 6 disc in dash, Hertz Hi-Energy 6.5" comps, MB Quart Ref 12", eclipse 5-channel sub amp.
    Car mods: Lowered on Mazdaspeed springs with Koni Yellow shocks, Racing beat front/rear sway bars with AWR end links, LED turn signals, tail lights, front side markers, 18" ADR Cypher rims, 55w HID's in low beam and fogs, 5% tint all the way around. No go fast mods yet...tuning and Mazda6 don't go well together .
    Steve a.k.a. ss3079: So this one lady goes, "These ignorant people who drive around blasting there music, they cant hear emergency vehicles"
    So that set me off, and I said "Well then why do they let deaf people drive?"
    AOL: JmKeenen
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    Quote Originally Posted by bumpin_blazer
    adam
    just a different shape....square and rectangular are no different than round...just clasified / refered to differently...they all acomplish the same objective.
    I'm back to stock in my new car.....
    russrocks's Avatar
    russrocks is offline Junior Member
    Jun 2003
    nYc
    27
    hes talking about end correction.
    when you have a port that uses a wall as one of its sides, one of the sides of the port has a 'free end', one has a 'flared end'. when the port doesnt use a wall as a side, both ends are flared.
    Do a search for 'correction' and you'll find a link explaining the whole thing. Its called DIY subwoofers(something like that)
    ws140's Avatar
    ws140 is offline ~`[]D[]][\/]][[]D`~
    Oct 2002
    MA
    33
    671
    Alpine CDA-9813
    Infinity Kappa 60.5s Component Speakers
    U.S. Acoutics 2080x for the comps (80x2 @ 4 ohms)
    1 ed e12O.44 in a 2ft.^3 sealed box.
    Soundstream RUB500-1 for the sub (400x1 @ 2 ohms)
  1. slot ported box vs Round ported
    By Primetime in forum Enclosure Design & Construction Help
    Last Post: 07-18-2003, 07:38 PM
  2. Swtchable Ports
    By Biohazard in forum Enclosure Design & Construction Help
    Last Post: 07-17-2003, 09:20 PM
  3. Slot port dimensions
    By debutis in forum Enclosure Design & Construction Help
    Last Post: 07-14-2003, 01:28 PM
