Results 1 to 12 of 12
Reload Thread: Some info in the difference between boxes
    IDSkoT's Avatar
    IDSkoT is offline Resonating Reticular
    Jan 2008
    Miami, Florida
    6,274
    Well, some kids wonder "ZOMG, WHAT BOX SHULD I USE?!?!?! IZ PORTED TEH BEST?!"
    Well, I used WinISD Alpha, I used a pair of Audiopipe TXX-15 drivers, with default specs.
    Here are said specs:
    Sealed:
    7.341 cuft
    Ported (AKA Vented):
    15.748 cuft
    tuned to 22.97 Hz
    4th order Bandpass:
    Rear chamber: 6.987 cuft
    Front chamber: 4.179 cuft tned to 40.99 hz
    6th order Bandpass:
    Rear Chamber: 3.531 cuFt tuned to 20hz
    Front Chamber: .925 cuFt tuned to 63.46 Hz
    Passive Radiator:
    7.341 cuFt using a 12" Passive Radiator from Parts-Express
    Now, the color chart:
    Sealed: Yellow
    Ported (Vented): Grey
    4th Order Bandpass: Orange
    6th order bandpass: White
    Passive Radiator: Purple (It could be pink.. I'm kind of color blind)
    For your hard-core people out there, this was done in WinISD @ 85* F, 75% humidity, and 101.325 Pa...
    Please note:: As you alter the tuning frequency on vented boxes, it becomes more "peaky", and won't roll off that flat. This goes the same for the bandpass boxes, as well. If I changed the 6th order bandpass box so the front chamber is tuned to 100hz, the whole line shifts and it has nearly the same response as sealed/vented/passive radiator in the 40-50hz range, and peaks really high in the 100hz range.
    Now, with that said, and the chart shown, note, this is just Db gains based on a computer model, and does not include the car's involvement...
    As most will tell you, it all depends on your car and your application.
    But, I just decided to put this together real quick to show each box's relationship to each other in perfect conditions.
    Now designing / building boxes.
    (Only building sealed and aero port boxes.)
    PM me.
    Feedback Thread
    Refs: MSW Danny, atsaubrey (great seller), ampjunkielikeme, wgsj_fortvalley, tEh koRnDog, bad @SS chevy, Nismos14 (who is the man. )
    Trey803's Avatar
    Trey803 is offline GAMECOCKS
    Jan 2006
    SC
    5,717
    56 Post(s)
    Re: Some info in the difference between boxes
    this is not saying much. This type of test is driver dependent.
    HU: DEH-80PRS
    Doors Deadened
    Front Stage: Rainbow SLC 265
    Front Stage Amp: Image Dynamics i2600
    Sub: Dayton RSS210HF-4 8"
    Sub Amp: Image Dynamics i2300
    Wire: Knu
    IDSkoT's Avatar
    Jan 2008
    Miami, Florida
    6,274
    Quote Originally Posted by Trey803 View Post
    this is completely relative to the drivers being used
    Yeah. I know. That's why I labeled the drivers. Like I said, it's just a relation based on the drivers I used.
    PM me.
    Feedback Thread
    snb778's Avatar
    snb778 is offline blaugh!!!!
    Oct 2004
    ex. Los Angeles, CA
    33
    8,022
    interesting... would have guessed the 4th and 6th would have higher peaks than the rest
    Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle (picked up box) mlstrass (box design) Mazzasec (bought 18" RD Alpha from him) SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic on steave meade forum. NJTStang11- picked up 18" SSX and box from him krispy cream SCAMMED ME $200!!!
    2 Pistol Shrimps in a 4.0 cu^ft box tuned to 32 hz for the WIN !!
    "You can't compare, don't stare, cause I got the ultimate Mary Jane"
    IDSkoT's Avatar
    Jan 2008
    Miami, Florida
    6,274
    Since Trey pointed out a very good point, I decided to do another "test" with a pair of IDQ10's. I used these drivers 'cause someone I know is ugnna make a build with them soon, so I thought, kill two birds with one stone...
    I also made the lines thicker so it's easier to read.
    Color chart is the same:
    Sealed: Yellow
    Now, the specifications of the boxes:
    Sealed:
    2.428 cuFt
    Vented:
    3.982 CuFt @ 24.5 Hz
    4th Order BP:
    Rear Chamber: 2.343 CuFt
    Front Chamber: 1.792 CuFt @ 50.53 Hz
    6th Order BP:
    Rear Chamber: 3.531 CuFt @ 20 Hz
    Front Chamber: .925 CuFt @ 63.46 Hz
    Passive Radiator [Using the same Passive Radiator as the first "Test"]
    2.285 @ 30.36hz
    Like Trey said, it is really determinant on the driver.
    PM me.
    Feedback Thread
    Rashaddd's Avatar
    Rashaddd is offline Terrrrrist
    May 2008
    Sacramento
    5,095
    this is pretty useless information
    Refs: themommyvan, CharlieAnderson, bassknocker23, bigbirney420, wu501, _JaY_, lrc131, R/T Pimp, NeverEnuffBass, d-REW, slapmaster, headbussaboi, edzy, adio, 1ndatrunk, jfink, k_schutte, bigredhybrid, ARSkemp, s-saudio, pimpdaddyq, AudioFreak, scarolinablazin, ssackett, kylebechtold, craigzter, etc..................
    IDSkoT's Avatar
    Jan 2008
    Miami, Florida
    6,274
    Quote Originally Posted by Rashaddd View Post
    Not really. It shows each box's relationship to each other in terms of DB output. The IDQ10 is pretty good all around, I could do some other drivers if you want. Most of the time it's the same results as the first chart.
    PM me.
    Feedback Thread
    Rashaddd's Avatar
    May 2008
    Sacramento
    5,095
    Quote Originally Posted by IDSkoT View Post
    It would be much more beneficial to explain their relationships and potential advantages. With this, the stupid people are going to look at it and pick the curve they like most, and conclude that is the best kind of box for their goals. The smart people will realize it is useless, and most already have a much more solid foundation of knowledge in terms of the differences between the box types.
    The people inbetween don't exist because this is CA.com
  9. #9
    photocrazy8's Avatar
    photocrazy8 is offline Probably doesn't like you
    Mar 2006
    CA
    3,920
    20 Post(s)
    its useless because that has nothing to do with car audio. it just models a drivers output and proformace in ideal situations which cars are not, each having different cabain gain etc...
    1956 Bel Air in the works
    Feedback Thread: http://www.caraudio.com/forums/buyer-seller-feedback/172118-photocrazy8-ftw.html
  10. #10
    Mar 2006
    CA
    3,920
    20 Post(s)
    also your average person does not care where the roll off occurs, they just want a Chebyshev allignment and max output...
  11. #11
    Immacomputer's Avatar
    Immacomputer is offline Cloud disappear
    Sep 2006
    Ocala/Oviedo, FL
    32
    4,672
    12 Post(s)
    Quote Originally Posted by snb778 View Post
    That's just the frequency response of the transfer function. The actual peak output of each enclosure will differ quite a bit. Each enclosure has a different efficiency to it and those graphs don't factor in sensitivity (and neither do the SPL graphs winisd will give you).
    Video 1
    I may make you feel but I can't make you think.
    Your sperm's in the gutter -- your love's in the sink.
    Video 2
  12. #12
    groundpound4200's Avatar
    groundpound4200 is offline Da fuq did I just read?
    Nov 2007
    Mankato, MN
    32
    5,250
    359 Post(s)
    do not.... I repeat...DO NOT build a bandpass box based on the estimated frequency reponse of winisd. It will not sound right Don't ask how I know
    2007 Honda Pilot 2008 Nissan Maxima
    2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
    2 Sundown Nightshade V.2s 2 10" Atomic APX
    Sundown SAX-125.2 x 2 Sundown SAX-100.4
    Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
    RIP Taylor aka NewAgeKing, you are missed!
