Results 1 to 3 of 3
Reload Thread: slot ported box vs Round ported
    Primetime's Avatar
    Primetime is offline Senior Hoopster
    Sep 2002
    Tx
    46
    458
    how much louder will a slot ported box be over a regular ported box with a 4" port be?
    Also, why do some people have more than one port in a box? ie 2 3" ports..
    Thanks in advance
    Dave
    BLAH!!!
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Let's see here.
    1. If the ports are the same dimensions there shouldn't be any difference. Usually with a slot port the actuall port area is alot larger. Which causes the difference in output.
    2. To increase the port area .
    5 % equipment
    90 % install
    5% beer
    Primetime's Avatar
    Sep 2002
    Tx
    46
    458
    Quote Originally Posted by ramos
    Let's see here.
    I dunnno, maybe I am retarded but I am not getting it. I looked up many online programs and the only options for the most part are round ports.. They say a certain width and a certain length depending on the size of the box and the desired frequency I want it to be tuned to.
    IF I were to use a slot ported box it alot more air would be let out at one time. (I am guessing that means that it would be what port area is, am I right?)
    Also if it is has bigger port area, does that mean it has to be a longer, or shorter port?
    Lastly, when building a slot ported box where does the volume of box stop assumeing it starts on a solid wall. IE do half walls count?
    D
    BLAH!!!
  1. 12" RF punch HE2/HX2 ported or (2) e10k ported
    By BIGGUP21 in forum Subwoofers
    Last Post: 11-05-2003, 05:31 AM
  2. 4 pioneer ts -w34c 12"s ported or sealed?????
    By phazeone in forum Subwoofers
    Last Post: 07-12-2003, 03:58 AM
