Results 1 to 2 of 2
Reload Thread: Will these plans from the Sticky work
    Nov 2008
    Owensboro KY
    84
    I need a box for a MA audio sub it says the ported box volume is 1.75 cubic feet so does that mean that this box will work for the sub i want to use?
    mcsoul's Avatar
    mcsoul is offline such is life
    Mar 2008
    dfw
    4,427
    Re: Will these plans from the Sticky work
    It will work, but you may want to choose a box tuned a little higher.
    MA recommends 39hz, but you could do 32hz or I think 35 or 36 at 1.75
    cubes may be better.
    ________________________
    Car: 2004 Nissan Altima 3.5 manual
    Head unit: Alpine CDA-9815 (running active)
    Midbass: Morel HU-621 Hybrid Uniflow 8 ohms
    Mid Amp: Audison lrx 4.300 bridged 2x140w @ 8 ohms
    Doors: 24ft Damplifier Pro, Second Skin D-flex pads, eggcrate foam, sealed up.
    Tweeter: SEAS 27TFFNC
    High Amp: Audison Lrx-2.150
    Subs: Two RE SE 12 d4's
    Box: 4 cubes net at 30hz
    Sub Amp: Sound Stream Van Gough 1600.2
    Electrical: Knu Flex 1/0, Batcap 2000 in back
    Rear Deck: No 6x9's just holes and grills
