Results 1 to 3 of 3
Reload Thread: sexxx help
    russrocks's Avatar
    russrocks is offline Junior Member
    Jun 2003
    nYc
    27
    sexxx help
    hey guys I ordered a sexxx 15 from teampsi, before it comes i want to start working on a box for it. He emailed me the specs -SE15
    Fs 30.0 Hz
    Re 2.8 DVC
    Qms 5.89
    Qes 0.52
    Qts 0.54
    Sd 810
    Vas 199.0 l
    Bl 18.1
    Spl 1W/1m 89.1
    I want to go ported with 2 square ports, so the setup will look symmetrical. Im looking to squeeze all the spl out of this thing as possible *without* losing sq. If pvc (or even aeroports) will work better Ill try that, although Im not sure how to brace it. I appreciate any help. Thanks!
    bumpin_blazer's Avatar
    bumpin_blazer is offline Only the Strong Survive
    Mar 2002
    Austin,TX
    36
    8,044
    Quote Originally Posted by russrocks
    Fs 30.0 Hz
    Re 2.8 DVC
    Qms 5.89
    Qes 0.52
    Qts 0.54
    Sd 810
    Vas 199.0 l
    Bl 18.1
    Spl 1W/1m 89.1
    i would go with 2.5-3.5cuft per sub more if you can give it up. ported to 45hz for SPL have a port block to slide in there and tune them closer to 35hz for daily.
    adam
    2006 Bright Island Blue 6s: stock 6 disc in dash, Hertz Hi-Energy 6.5" comps, MB Quart Ref 12", eclipse 5-channel sub amp.
    Car mods: Lowered on Mazdaspeed springs with Koni Yellow shocks, Racing beat front/rear sway bars with AWR end links, LED turn signals, tail lights, front side markers, 18" ADR Cypher rims, 55w HID's in low beam and fogs, 5% tint all the way around. No go fast mods yet...tuning and Mazda6 don't go well together .
    Steve a.k.a. ss3079: So this one lady goes, "These ignorant people who drive around blasting there music, they cant hear emergency vehicles"
    So that set me off, and I said "Well then why do they let deaf people drive?"
    AOL: JmKeenen
    russrocks's Avatar
    Jun 2003
    nYc
    27
    okay somethings gotta be wrong here, maybe Im just a *******.
    I entered in the specs, some of them must be off because when I enter some, winisd automatically calculates the others and they dont match what I have.
    Then in (box) It recommends 18 cuft tuned to 22 hz
    I change that to 3.5, tuned to 33 hz
    Then I click the Vent tab.
    For one square port, it tells me to use a 4*4*8 port.
    If I change number of ports to 2, it tells me to make each one 4*4*19.5 ... yeah that makes sense
    please help Im dying to get this thing in my car!!
